Autotrail Cheyenne Electric Step Stopped Working
Discussion in 'Tech/Mech General' started by Phil J., Aug 31, 2015.
  1. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    Clay Cross, Derbyshire
    Hi,
    2007 Autotrail 696.
    The electric step has suddenly stopped working and is stuck out after, I suspect, driving through this morning's heavy rain. when we arrived home to unpack, it came out but now it won't go back with the remote central locking, the switch or by starting the engine. I've taken the cover off the limiter switch and it appears dry and I've given it a good squirt with maintenance spray. The other thing is that the interior light above the door that normally acts as a courtesy light when you unlock won't work on the switch as it does normally independendent of the step.
    Is it possible that a fuse has gone - if so, where is it? I've checked all the Sargent ECU325 fuses and all are OK.
    Any help would be gratefully received as I'm stuck with the step out that won't retract.
    Phil
  2. alan
    alan Funster
    Aug 21, 2008
    536
    481
    skegness / spain
    The fuse for the step is under the engine bonnet against the battery, there are about 4 fuses in a block and I think it's the second one in
    Alan
  3. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    Thanks Alan, however our batteries are under passenger seat, its a 2007.
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    the step should just push in by hand ok. If the fuse has blown it is likely the step mechanism is encrusted with crud causing a high current drain when used. Sorry no idea where your fuse is but cleaning all bolts and pivots should reduce the load. It is recommended NOT to grease as grease collects crud.
  5. alan
    alan Funster
    Aug 21, 2008
    536
    481
    skegness / spain
    didn't
    My 696 was a 2006 model and the leisure batteries where under the bench seats but the engine battery was in the engine compartment with the step fuses coming from the engine battery.
    I had the same problem after travelling in heavy rain and travelled from Mimizan in France to near Valencia without realising it was out.
    good luck with rectifying the fault.
    Alan
  6. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    I have fixed it!!
    After removing and checking every fuse on the vehicle, not finding a thing and being very peed off with it I decided to pack up for the day. I guess i must have jumped out of the door and and landed a bit heavy on the step.........yes, you've guessed it, a bit of a grunt and, hey presto, step retracted!!
    It's working perfectly now after several tests with the button and the central locking so my guess it it stuck or there's some crud lurking. I'll clean it up and oil it and, hopefully, it should be ok.
    • Like Like x 1
