Autotrail charging failure
Discussion in 'Tech/Mech General' started by Southampton, Aug 28, 2013.
  1. Southampton
    Southampton Funster Life Member
    Dec 16, 2011
    514
    298
    Hampshire
    My Comanche (2013 model) on board charger has stopped charging when on EHU. I have checked all the visible fuses but there is no charge going into the batteries. I have had the same problem previously and the dealer said it was a loose connection in the rear of the unit. The dealer cannot look at it until the end of September ! None of the local dealers can fit it in either, but I need to use the van now (mother seriously ill in Cumbria and hotels are expensive). My question is, how easy is it to remove the unit from its housing to at least check the connections on the rear. Is it just a case of undo the 4 screws and ease the unit out? Would this negate the warranty? It is an EC500 unit. The batteries will charge when the engine is running. The other question is, can I just run on EHU without discharging the batteries? If so what do I need to do. Any advice would be appreciated.
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,102
    77,163
    Sutton on Sea
    Give Sargent tech support a call, I forget what my problem was, but I remember their helpful tech talked me through a simple detect and repair job which necessitated me removing a similar panel.
    I should say though that this was about 10 years ago and elf and safety and similar procedures might mean they cannot help to that extent today. Still worth a call though :thumb:
  3. Chris
    Chris Funster Life Member
    May 5, 2010
    16,563
    35,241
    kent
    You could try calling Johns Cross. Glenn there knows his onions.
  4. Chris
    May 5, 2010
    16,563
    35,241
    kent
    Thinking about it we had a similar problem with our autotrail.
    This might not help but have a look in the leisure battery compartment. To the left of the battery are two red leads, one coming from the van, the other from the LB. Just check they are connected properly.
    Ours had worked loose.
    Good luck.
  5. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,476
    1,325
    SW Northumberland
    Remove the 4 screws and gently slide out the charger there is sufficient cable to pull it right out and allow it to hang without support. All connections can then be checked.
  6. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Thanks guys, I am going to try all the suggestions, however I have decided to hot tail it up there and use a hotel for a few days. I will spend some time on it after the weekend when I get back. I will let you know if I manage to solve it.
  7. Chris
    May 5, 2010
    16,563
    35,241
    kent
    Hope your Mum is ok.
  8. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    Your dealer can't look at it until the end of September!!! What sort of dealer is he, he's taking the proverbial. What's a couple of minutes of his time going to do to his booked up schedule. Your rig has cost an arm and a leg and you have been fobbed off.:Angry::Angry:
    • Like Like x 3
  9. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,476
    1,325
    SW Northumberland
    Picture attached to give you a better idea
      File size:
      95.7 KB
      34
  10. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    As has been mentioned, give Sargent a ring on their help line quoting your Autotrail build number, its possible that the charging unit is faulty and they will send a replacement overnight free of charge. All you will have to do is change over the connectors, you can't mix them up because every one of them is a different shape. Put the old one back in the packaging, ring them up and a courier will call and collect it. Their customer after sales service is simply the best. I have had three replacement units exchanged in a similar manner.
  11. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Thanks Rolandrat, I will do that when I get back. They may be able to talk me through a simple fault finding. Just arrived in Cumbria but hope to get back early next week.
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    [​IMG]
    too complicated by far....old models never suffered electronics failure 'cos they were simplicity...and reliability... itself.
  13. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,476
    1,325
    SW Northumberland
    Kinda messy aint it :Eeek:
  14. smiffy502000
    smiffy502000 Funster
    Aug 5, 2012
    220
    118
    sutton coldfield
    after spending that sort of money,i think I would have camped outside the dealership and refused to move until he had sorted it out!!!!
  15. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Just took the unit out and found two faults, one wire (neutral) hanging out of one of the connectors, so recrimped it back in position, and the connector on the far right of the photo was really loose that when touching it very lightly you could see arcing and hear a relay clicking away. After crimping the loose wire back into the connector I then secured the second connector in position by using a couple of small cable ties. The connectors used are not very good and look a bit iffy. Anyway, all back in place and working as it should do. Thanks for the suggestions and help.....Derek
