Autotrail Apache 700 tv points (1 Viewer)
Tony drake
68
45
Poole
Coachbuild
Since 2008
Having been away for a couple of days down at freshwater bay Bridport with my family made up of 1 wife and 3 daughters, trying to watch match of the day was a struggle I have to say.
Whilst packing up today I suddenly noticed that I have 2 tv point cables coming from the aerial box in the cupboard. One obviously goes to the drop down tv at the back but I was wondering if the spare cable goes to the front and one of you good people could tell me where so I can get another to mounted at the front somehow.
Thanks for your help.
Nov 13, 2012
440
438
Somerset
coachbuilt
since 2000
In my Apache 700 there is the drop down to in cab and a second point in the rear lounge
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
Mine has the drop down factory tv fitted in the back and works fine. I want to fit another at the front but didn't know if anyone knew where the cable is hidden.
TheBig1
17,618
43,200
the valley that freshwater sits in makes tv reception a bit hit and miss. Have camped on the rally field next door dozens of times and regularly had people complaining they couldnt get tv
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Mine also has the drop down TV in front and another socket in lounge. I had one put in at the overcab bed too.
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
@Tony drake do we assume that you have nothing in the front of the cab then ?? Is no media packed fitted..
Usually the cable would be behind the radio so could be worth pulling it out and having a look. It's the most obvious place as it would be needed there to connect to any add on media system.
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
I'm not sure if I have the media pack??
I have sat nav, radio, rear camera etc and rear lounge tv already fitted when I bought the van but I can see 2 tv cables coming from my aerial box so I want to find the other end in the front where ever that may be as I'm assuming it goes to the front somewhere.
tonka
10,829
21,524
Cannock, Staffs
Since 2000
Simple.. Is there a drop down screen in the cab ?? Or a TV screen on the radio unit....?
If neither of above then as suggested, the cable may be tucked away behind the radio ready for when a media system with TV is fitted..
I see you have a new Fiat cab, not sure what they are fitting as standard now..
Usually media pack is an optional extra that you pay for... Check your invoice.
Feb 22, 2011
9,780
20,143
Newcastle under Lyme
Hymer B544 A Class
Since 2015
With four women in the family your always going to struggle to watch MOTD ! no matter what you try
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
No drop down screen in the cab or tv on the radio so I'll pull the radio out and have a look for the cable. Thanks for your help tonka.
Scout
3,959
121,096
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
The radio screen but there's no tv available on the radio.
ah are you sure, the tv sound comes from the radio, the tv picture is on thew rear veiw camera screen, in older units like mine you had to tune the radio to a Fequency to get sound, on the newer ones I "belive" have a direct sound input like an Aux input you chooose and select tv input somehow on the screen, berhaps owners of newer style units could help you more on that.
all that is above asumes its a standard fit radio and has not been changed to aftermarket
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
Oh ok I'll take a closer look at the radio too then.
Mine is standard radio and nav.
Scout
3,959
121,096
South Yorkshire
chic c line
just noticed your in poole, I think funster @breakers ? is near you and has a simular age autotrail why not pm him pehaps he might be able to help more
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
Lol I like that way better.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Are you sure that one of the two wires coming out the "Arial Box" is not a wire IN from the Arial and a wire OUT to the TVo_O
Tony drake
Tony drake
68
45
Poole
Coachbuild
Since 2008
Yes geo. it has 1 input and 2 output saying tv1 tv2
Angela Johnstone
5
3
Derbyshire
I am a Newbie this week
Hi I have a small screen for reversing camera and dVd's A little remote that I do no know for what and a drop down TV which does not seem to be a TV Does anybody know what to do and can I upgrade Radion cd and reversing camera unit to become a Sat Nav as well Autotrail 700 2010
tonka
10,829
21,524
Cannock, Staffs
Since 2000
@Angela Johnstone looks like you have used all your free posts.. £15 is the annual subscription to be a full member. Good value for all the info and hep you could gain..
Ref the Drop down.. It is a monitor for the rear view camera. There should be a black switch to turn it on and other controls inside the top cupboard behind the drivers seat.. Same place as the Sargent power supply / charger..
