Autotrail Apache 650 SE wiring diagram
Discussion in 'Motorhome Chat' started by olympus, Dec 24, 2013.
  1. olympus
    olympus Read Only Funster
    Dec 24, 2013
    8
    High Halstow. Kent
    Hi all,
    Does any one have a full wiring diagram for my van ....as the one in the Autotrail handbook is for the standard Apache & not the SE
    I specifically need this to find out why the Omnistep powered step isn't auto retracting when the engine is started.
    In addition is the feed taken from the alternator D+, off the charging tell tale or from somewhere else??
    Many thanks
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,285
    7,981
    West Norfolk
    Hi Welcome!!!
    What year is your Apache? You can find most of the wiring diagrams on the Sargent electrical website.
    You will probably find the fault lies with the limit switch actually on the step linkage. Crud gets in the slot and stops it working. A good WDing and working the switch by hand might sort it.
    The feed will come from the yellow and red cabled fridge circuit, probably!!!!!
  3. olympus
    Dec 24, 2013
    8
    High Halstow. Kent
    Many thanks for this, I'll work through the problem starting with the basics
    My van is a 2003 Apache.
    Do you have the Sargent web address??
  4. Hellboy
    Hellboy Funster
    Nov 26, 2009
    64
    19
  5. olympus
    Dec 24, 2013
    8
    High Halstow. Kent
    Spot on Mr Gaz. many thanks:thumb:
  6. Hellboy
    Hellboy Funster
    Nov 26, 2009
    64
    19
    No problem...good luck with you fault finding :Wink:
  7. Baycott
    Baycott Funster
    Nov 6, 2013
    6,458
    12,989
    East Sussex
    I had this problem in my Tracker. It turned out to be a fuse in the split relay box which lays beside the vehicle battery.
    Hope this helps.
    Have a great Christmas and enjoy your new MH
    John:thumb:
