Scout
- Apr 4, 2009
- 3,959
- 121,136
- chic c line
- 12 years motorhoming, a lifetime of living
My new to me autotrail Arapaho, bought privately, as 3 leisure batteries
No: 1 is connected by the autotrail harness with a 20amp fuse,
No: 2 also is connected by the autotrail harness with a 20amp fuse,
No:3 is connected to no:2 by some heavy looking cable and does not appear to be fused in its own right, it’s just connected to the terminals of No:2, so both 2 & 3 are protected by 1 20 amp fuse? This is making 2 & 3 into one big battery?.
The 2kw inverter is also connected to the terminals of no: 2 there does not seem to been a fuse or isolator switch for this. This to me does not seem correct?
Fitting extra solar panels to an autotrail
I already have the standard fit 85watt solar panel wired to the Sargent charger with built in controller. I’m thinking of add extra solar panels to keep up with the inverter usage and feed the leisure battery’s, probably 2X 150 watt, from what I understand this should have an independent controller with the output going to the leisure batteries, is this correct?
Comments please, please note whilst I have a basic ground with electric, at the moment I have chemo brain and I’m not 100% fit.
