Autosleeper tow bar (1 Viewer)
nerdycross
4
devon
I am now a proud owner of a Autosleeper Talisman on a 2.8 Peugeot chassis and I am wanting to make a tow bar for it.
I have access to a welding shop and want to fabricate my own,Is there any body out there with a drawing or maybe some photos,of the tow bar for the Talisman or Excutive.
Any help would be great :Smile:
43,318
49,372
If you intend making your own then make a mental image of what you want.
then get underneath and take some measurements.
If your van is on an Alko Kober chassis then on no account start drilling holes in it, use the pre punched holes only as it's a galvanised chassis and will rot faster than an apple on wet grass where its been drilled.
I made my own and it looked OK on my Swift Kontiki
N
nerdycross
4
devon
Ok,
Thank you for the advice I will get my tape measure out and make a start this weekend.
:thumb:
Johno
87
38
Kent
Low Profile
30+ with caravanning & camping
Hi Nerdycross
I am not a 100% sure of this but I think that tow bars fitted to motorhomes registered after 1st April 2012 have to be EC approved it may be worth checking this out before starting work on the tow bar , also I think the tow bar is now part of the MOT test which checks fixings and for corrosion.
Cheers John:thumb:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Hi Nerdycross
Cheers John:thumb:
This is true but as the OP's motorhome has a 2.8 engine it must be pre 2007 so this doesn't apply.
D.
43,318
49,372
Ok,
:thumb:
took me a few hours of careful measuring and sketching then ripping the lot up and doing it all again, and again, and again :Sad:
a couple of longish lengths of 2" x 1" wood helped to find the clearances need for the rear skirt and a 'protractor' ( 2 short bits and a wood screw :RollEyes:) to find the angles.
I used 60mm box for the bar and side rails and 10mm plates for the mounts.
M12 bolts to fix to chassis using original Alko holes.
