autosleeper electric hook up
Discussion in 'The Beginner' started by camper_crazy, Feb 14, 2011.
  1. camper_crazy
    camper_crazy Read Only Funster
    Feb 13, 2011
    bristol
    Hello
    I have a 10 year old autosleeper trooper and was wondering if someone could give me some advice regarding the ellectric hook up, say when im plugged into the mains is this then charging my leisure battery or not? only reason i ask is my control panel shows the needle going to the end of the scale if im on hook up wheras if im on 12v it goes to about 3/4 of the scale?
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    Yes when on hook up, the leisure battery should be getting charged.
    Peter
  3. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    I am not sure on the control panel fitted to your motorhome but on my Autosleeper panel the left hand switch is a 3 way one. Top pressed for charging the Vehicle battery, centre no charging (off) and bottom pressed for charging the Leisure battery.
    The voltage shown is always higher when plugged into the mains as it is showing the voltage from the controller which supplies the 12 volts once the mains is plugged in.
    Mike
  4. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,735
    15,540
    North Wales.
    Hello Camper crazy and welcome to Motorhome Fun:welcomefunster:
  5. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi Campercrazy
    Welcome to MH Fun .:welcomefunster:
    Dave .:thumb::thumb:
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    If, as gozomike said, it is a three position switch then having it in the center position there will be no load on the battery charger and it may show an unusually high voltage.
    on my old kontiki, if in the center position and not hooked up, the solar panel would 'pulse' the needle from about 11v to off the scale.
    switch it to the position with a pic of the rear end (or the word 'HAB') and the charger will be doing its job.
    put it in the other position, pic of cab (or word 'CAB/ENG'), it will charge the engine battery instead.
