autosat 2 dish problem
Discussion in 'TV & Satellite' started by des, Mar 29, 2008.
  1. des
    des Read Only Funster
    Oct 1, 2007
    128
    south staffs
    a particularly violent gust of wind has broken my dish drive. the dish is now free to move up or down, rather than being driven and locked by the motor. i assume there is a pin or similar somewhere inside the unit which has sheared. any expertise out there?
    des
  2. adventure
    adventure Read Only Funster
    Oct 16, 2007
    131
    somerset
  3. des
    Oct 1, 2007
    128
    south staffs
    thanks nick. will speak to them monday.
    des
  4. des
    Oct 1, 2007
    128
    south staffs
    now the wind has died down, have been up to inspect properly. bolts had loosened, so i have tightened them. dish now operates correctly, but signal is very weak. suspect either damage to lnb or lnb alignment problem.
    des
  5. adventure
    Oct 16, 2007
    131
    somerset
    Thanks for the update Des, you may find that the skew angle has shifted it is just a case of turning the lnb to the correct setting, easiest done once the dish is up and locked so you can see the signal strenght and quality
    nick
  6. des
    Oct 1, 2007
    128
    south staffs
    hi nick
    thanks for that. have had a further play. receives sky news ok, but other channels v. poor or no signal. itv1/2 ok-ish, but nowt on bbc channels. so i assume the lnb must be ok. what is skew angle, and how do i adjust?
    des
  7. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    LNB rotational position ("skew") has to be set to the correct angle so that horizontal and vertical signals are received with equal strength. It optimizes the cross-polarization isolation between signals of vertical and horizontal polarizations, and has strong influence on quality of digital signal.
    Basically standing in front of the dish it's like turning a steering wheel one way or the other:Rofl1::Rofl1::Rofl1:
    [​IMG]
    Of course make sure the van is level before you start!!
    Regards Pat
  8. des
    Oct 1, 2007
    128
    south staffs
    thanks all.
    it was the skew angle. while i was a dave's motorhomes, having another job done, he jumped (climbed) up on the roof, and set it to the correct angle. all perfect now.
    des
