Bart
Hi both my Hot water and heating is working 100% fine manually , on gas or electric
My problem is that the knobs / buttons must be used in a certain sequence or i will get the "red" error light, and having to do it in this said sequence means that i am unable to get either hot water or gas working automatically via the control panel timer.
So i'm not sure if i have a problem or its operator error
here is what i must do to get it to work without getting the red error light
1. Ensure Knob "A" is in the OFF posiition
2. Then turn on Switch "B"
3. then Select if you require hot water or heating or hot water + heating
This way all will work fine with there just being the green light and the orange light until the correct heat / temp has been reached
NOTE : it does not matter what power source i select its the same for either gas or electric , or both
Now as far as i am aware for the automatic timer feature to work you must have Knob " A " selected to they type of heat / hot water that you require , then when the timer reaches the correct programmed time it will automatically turn on Switch " B " and it should start running , however when i operate my heating OR hot water in this sequence i always get the red error light.
Am i doing something wrong ?
Or is something Fked ?
