Autocruise Starfire (1 Viewer)
Scotts
West Yorkshire
Autocruise Starfire
Since 2016
Hi there
We purchased an Autocruise Starfire 1999 earlier this year - our first MH - and are in the process of storing it away for the winter. However we did not receive a handbook with the vehicle so we are finding our way around bit by bit. The question I have is can anyone tell me how to drain down the hot water tank? Have drained down the cold water and waste water tanks but we are unsure as to where we drain down any water which may be left in the hot water tank.
TerryL
6,184
8,184
North East
Low Profile
Somewhere close to the tank will be a sort of tap, probably coloured red, on a pipe that runs outside/through the floor. That just lifts up and the tank should then drain down - best to leave it open until you come to refill (don't forget it.......!) As regards the rest, without something to blow residual water out it is next to impossible to clear all the pipes so we just open them fully and also put the shower-head into the tray. Mixer taps should be set in the middle position. Also don't forget to empty your cassette - and the flush tank if yours is separate to the main freshwater tank.
Oh and :welcome3: any more questions just ask away - you're never far from a solution on here!
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Someone didn't and when taken in for a service this was the result:-
Wyn
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
On my StarSpirit it is located next to the boiler. See pic attached.
Lift the yellow tap to the vertical position to drain.
