Autocruise Starblazer (2003) (1 Viewer)
Will
7
5
The tyre pressures for this vehicle are 78psi all round. Just in case the doorpost sticker has gone missing. I had this confirmed by express motorhome services.
Will.
ingram
87
I have a handbook with my 2006 Starblazer XL and the tyre pressures are nowhere* near* as high as that: I have just packed the book away... will fish it out if anyone interested in what it says ..
Harvey
W
Will
7
5
tyre pressure.
Hi Harvey.
I am somewhat confused now. I wonder if you would be so kind as to tell me what your handbook says the pressures should be.
Kindest regards
Will
Oct 26, 2007
15
Teesside
Swift Edge
I used to own a 2003 Starblazer and the sticker on the door did say 78psi but when I contacted autocruise they advised 57front and 65rear as I found 78 to be a .very firm ride
ingram
87
Hi Harvey.
Kindest regards
Will
This is for a 2006 Starblazer XL ( that is the extra long wheelbase one ) with a GVW of 4150kg.
Front 47psi
Rear 55psi
Regards,
Harvey
ingram
87
Delayed update due to being away in the *Starblazer*::bigsmile:
The handbook says these pressures are as recommended by Michelin: just adding that to clarify.
Harvey
Front 47psi
Rear 55psi
Regards,
Harvey
ingram
87
Having been unhappy about the disparity in the pressures given from different sources I have done some questioning.
I suggest that you contact the manufacturer of your tyres and ask them.
They may say that you should get the actual 'in running order' axle weights from a weighbridge but if you give them the maximum axle weights for your vehicle and the type and size of the tyres they may advise a maximum pressure.
The maximum axle weights for my 2006 Starblazer XL are:
MTPLM 4150
Front axle: 1850kg
Rear axle: 2300kg
I have been advised that pressures should be:-
Front 60psi
Rear 70psi
These pressures may need to be reduced if after weighing I find that I am nowhere near maximum weight.
I hope that is of interest to you other Autocruise owners.
Regards
Harvey
