Autocruise locker seals (1 Viewer)
markh
247
243
C class
Lots
I'm sure I've seen a thread on here that shows a seal used to fill the gap around autocruise locker doors, but I just can't find it. Can anyone point me in the right direction for the outer seal, I've looked at seals direct but can't identify the one for the job
icantremember
8,318
17,527
Near to Watton in Norfolk
Hymer T-SL668
since 2005
You don't say which model you have but when our Augusta went back to the factory for some repair work 2 or 3 years ago they also fitted seals around all the lockers without telling me they were going to.
It may be worth a call to the factory or try a dealer for a supplier.
SandT
127
383
Malta
Safari Trek
Newbie
This link from another forum.....
I've just fitted this to my Stardream on the slot around the locker doors , it fits into the 10mm slot well with only a little squashing and stays put.
I used 6 metres in total, should make the lockers weather tight at last
Terry
M
markh
247
243
C class
Lots
Its a 2010 Stardream, with the 10mm slot around the locker door, sadly the swift part is for an 8mm slot around the locker door, so doesn't fit
M
markh
247
243
C class
Lots
Thanks Terry
I found that too, but the link is to a whole page of seals so I don't know which one was used
fleurette
253
156
worcester
A Class Frankia I640 SD
You might find what you want here, www.sealsplusdirect.co.uk they have a section for caravan/motorhome door seals. they'll send you out a brochure with actual size photos and free samples as well.
Nigel
M
markh
247
243
C class
Lots
Thanks Nigel
I downloaded the catalogue and used the actual size profiles to order some samples
fleurette
253
156
worcester
Glad that it was of help (y)
