Auto trail (1 Viewer)
DIESELGIPSY
5
UNITED KINGDOM
RV HI TOP
2 years
I have an Auto trail scout. On the control panel it keeps flashing up that the waste water tank is full,even when it's empty! Also I can't set the clock. Any help to rectify this would be much appreciated.
tonka
10,829
21,525
Cannock, Staffs
A class Burstner 800
Since 2000
What year scout as there are several different control panels and power control units..
The water thing may be just a stuck sensor or faulty, My one in a newish 2012 van never reads properly...
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
They're never very good. I had this problem once, just crud bridging the sensor wires in the tank. Spaghetti is the worst:Smile:
D
DIESELGIPSY
5
UNITED KINGDOM
RV HI TOP
2 years
My scout is a 2001. When I press the buttons to alter the clock nothing happens!
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Hope this works, it does on mine..an 06 Scout !:thumb:
Press the left hand button (clock) down and hold it down ! The time will alter slowly then more quickly ! When it gets near to the time , release the button then re press it for the slower speed :Cool::Cool::Cool:
FM02MZO
216
36
Castle Donington
Coach Built
30 years caravan, 2 year motorhome
On our Mohican, you have to remove the panel front and take the battery out for around 30 seconds, the system then reboots itself
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Our new Comanche has the same problem re tank level.
It reads half full (or half empty, depending on your mood ::bigsmile:) and the drain tap is open.
As has been said, gunge on the sensors.
sennen523
45
14
Rhos-on-Sea, Conwy, North
Coachbuilt.
Started 2007.
Hi Dieselgipsy.
If it's the same switch as mine, it will almost certainly be the float on the switch in the tank stuck in the "up" position indicating 100% full.
Assuming it's the same as mine, you could clean and free the float. This is located on the side of the waste tank. This is just pushed into the tank with a rubber bung. Make sure you put it back the right way up (note the flat edge on the switch for reference).
Hope this helps.
sennen523.
