Auto Trail Tracker Se 2003 (1 Viewer)
Weekender
5
Hertfordshire
Auto trail
Newbie
Hi we have just purchased an auto trail tracker se , the leisure battery is reading 4.6volts , we have plugged it into the electric hook up and switched on the charger in the wardrobe, and seem not to be able to increase the power in the battery. How do we charge the battery please.
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Sounds as if the battery's knackered, they can't go that low and survive, you could try jump leads on it from a full battery and it might just kick it into charging but it's a long shot I'm afraid:(
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
I agree... "Knackered"....
Go buy a new one, would be wise anyway with a used van...
W
Weekender
5
Hertfordshire
Auto trail
Newbie
Thanks I bought the MH private , I will purchase a new battery at the weekend and we guess when we tow or we are on an electric hookup it will the charge the leisure battery up ?
Feb 9, 2008
8,949
18,704
Corby, Northants
Coach Built
Do you have a solar panel fitted. (I guess not, hence the flat battery). I would advise you get a solar panel fitted (the bigger the better) and consider a second leisure battery if your going to spend any length of time of hook-up.
This attachment will help you with the selection of the right leisure battery. (go for Vatra or Banner)
Broken Link Removed
Feb 9, 2008
8,949
18,704
Corby, Northants
Coach Built
As an afterthought, purchase a volt meter (around a tenner) and check the onboard charger is working. When switched on (the battery charger) you should expect around 14.4 volts going into the battery.
