Auto trail - shower wall replacement
Discussion in 'Tech/Mech General' started by jac-in-a-box, Oct 8, 2014.
  1. jac-in-a-box
    jac-in-a-box Read Only Funster
    Sep 9, 2014
    161
    95
    2005 Autotrail Dakota
    Slowly working through all the little (and big) jobs that need doing to get the m/home up to a standard I want.
    One of them is the repair of rear shower wall. I've got a lot of very fine vertical crazing running virtually top to bottom . I'm going to guess these are stress cracks....seems the rear wall is bonded to a wooden frame and whatever has been used to bond it has dried out and there is no flexibility left, if it's the same stuff that's been used to seal the panel edges which is rock hard it's little wonder the wall is distressed.
    So, how best to repair?
    Cut out the bulk of the panel and leave a margin of an inch or two to bond a replacement panel?
    What adhesive to use - I've got a few tubes of Sikaflex 221, good enough?
    Replacement panel - 3, 4 0r 5mm acrylic sheet? whatever thickness sheet is used at the moment seems very flimsy. Perhaps use 3mm sheet and add some extra framing to support?
    Any other thought on materials and approach gratefully recieved!
    Thanks, David
  2. Mikeco
    Mikeco Funster
    Sep 26, 2013
    732
    543
    Market Rasen
    I would not cut the existing out as it will weaken the whole thing, I would just bond a new 3mm acrylic to it.
    Mike
