Auto shut down wire
Discussion in 'TV & Satellite' started by Baycott, Jun 6, 2016.
  1. Baycott
    Baycott Funster
    Nov 6, 2013
    6,372
    11,609
    East Sussex
    I am about to install a satellite dish and the instructions state that for for automatic closing of the dish when starting the engine, the yellow wire must be connected to '+15 vehicle line'.
    Apparently, it should carry a voltage (I assume 12vDC) when engine is on and no voltage when engine is off.
    Can anybody tell me where I can pick up such a feed?
    For info I have a Swift Bolero 684FB
    TIA
    John
  2. laneside
    laneside Funster
    Aug 14, 2009
    3,544
    5,505
    Oradour sur Vayres
    often the best place is behind the fridge where it switches to 12 volt when on the move. I must admit Iignored it but of course have to remember to put the dish down before every journey. I guess if you have an auto step there is summat similar
    • Thanks Thanks x 1
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,108
    14,922
    Leeds the one up North
    On Rapido it is already provided at the satellite or TV connection point in a wardrobe or cupboard. Are you sure yours has no such feature? Usually marked as a D+
    • Thanks Thanks x 1
  4. scotjimland
    Jul 25, 2007
    28,934
    25,590
    I used the 12v supply to the fridge that is only live when engine on.. 3 amp inline fuse fitted at supply end.
    This was very convenient as the dish is mounted above the fridge .. I picked the connection up in the wardrobe next to fridge.
    It's worth connecting.. it's all too easy to drive off with a dish up.. did it a few times with a Maxview manual crank up
    • Thanks Thanks x 2
    • Like Like x 1
  5. Baycott
    Baycott Funster
    Nov 6, 2013
    6,372
    11,609
    East Sussex
    Thanks for that. I noticed that, in the cupboard above the fridge there is a false back, having removed the cover I found a plug marked Satellite connection :blush::doh:
    It has 3 wires one of which (yellow) is +14v with the engine running (y)
    The decoder has the wires below.
    Red, Brown and Yellow. I assume the two yellows should be connected but wonder if it matters which way round the other two go?
    • Like Like x 1
