Auto gas fill up (1 Viewer)
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
just refilled my auto gas tank for the first time, WOW i was not expeting the huge blowback when disengaging, it was so fierce it styled my hair into a center parting,
pete
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
pete
I think you may have just solved one of the female motorhoming community's greatest problems. No need to ask about installing a huge inverter for the hairdryer - just get a refillable gas system fitted, then ask the other half to fill it.
Aug 31, 2009
107
44
Lot-et-Garonne, France
Changing
15 Years
pete
Saw it all mate...pic attached..
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The UK decided to use a nozzle that harbours half a litre (perhaps I exaggerate:Smile:) between its valve & the filler valve. The French device (which is much lighter, easier to handle, and to engage with the filler) simply makes a little pfft noise.
But we do things better than they do don't we? :RollEyes:
TheBig1
17,630
43,266
a tiny bit of liquid gas is released, this boils off immediately and expands to many many times its original volume. what can appear a lot to the casual observer or somebody experiencing it for the first time releasing the coupling is actually not as bad as it appears to be
golly
2,005
69,615
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Keep a pair of gloves handy for when filling, LPG can cause a "freeze burn" if you come in contact with the escaping gas.
GJH
29,450
38,827
None, now sold
2006 to 2022
I bought a pair of rubber gloves (like heavy duty Marigolds) not just for that but also to give a better grip for unscrewing the adapter after it once got a bit tight (garage attendant put it on).
GJH
29,450
38,827
None, now sold
2006 to 2022
[HI]The UK decided to use a nozzle that harbours half a litre[/HI] (perhaps I exaggerate:Smile:) between its valve & the filler valve. The French device (which is much lighter, easier to handle, and to engage with the filler) simply makes a little pfft noise.
Is that the De Visser gun? I find the Gas Guard one easier to use and doesn't seem to release as much gas.
scotjimland
2,320
10,005
A Woosh bang
pete
The new Euro connector has no escaping gas when you disconnect .. :thumb:
[ame="https://www.youtube.com/watch?v=EYvAD2naC_s"]https://www.youtube.com/watch?v=EYvAD2naC_s[/ame]
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
True - but the amount released is that held between the filler lever valve and the tank filler non-return valve. Good filler/nozzle design should seek to minimise it and should make the filler nozzle as easy to use as a petrol pump nozzle. The UK nozzle does neither of these things and is unwieldy as well. The French one is foolproof, light, and traps considerable less LPG after shut-off. The British one appears to have been chosen (not that long ago) to provide a UK company with a captive market.
