Auto Dump Valve
Discussion in 'Tech/Mech General' started by rangitira, Mar 19, 2012.
  1. rangitira
    rangitira Funster
    Jun 30, 2010
    6,324
    12,831
    Cornwall
    Seem to have a bit of a problemo, My Frost Protection Dump Valve isn't working, it won't close:Sad:
    We last used our M/H in Jan, when we came home we (actually thats ME!, Mrs R thinks she's on holiday as soon as we leave the drive, and when home "technical stuff is your Department"), But I digress!:Doh:
    I emptied the System, wiped out the Tank, left all taps open and pushed the dump Valve down, to open it.
    Today, because we are going to a Rally over the Weekend , I decided to test the system, only to find the Valve no workee:Angry:
    Question; Did I do something wrong?:Doh:
    If the valve is U/S where do I get a replacement, and if I have To, can I bypass the blinking thing temporarily, without causing a problem until the part arrives.
    Tried Geoff Cox, still waiting to hear back from them.
    Any advise gratefully received as always: :notworthy::notworthy:
  2. BwB
    BwB Funster Life Member
    Apr 3, 2011
    607
    563
    Brandon Suffolk UK
    What was the air temp when you tried this? I only ask as I did the same thing today and had a bit of a panic but then wondered about the air temp where the valve is. So waited until this afternoon once the sun had come 'round and bingo, it stayed up.
    We had quite a heavy frost this morning so I guess the 'van took a while to warm up.
    Just and idea.
    PS, a peg is the temporary answer to the fix. Lift up the plunger and clip it with the peg :)
    • Like Like x 1
  3. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,575
    11,762
    Champagnac-La-Riviere
    Will watch this with interest as ours "dribbles" occasionally. Is this normal or do I need to think about a replacement? Thanks. :Smile:
    • Like Like x 1
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    comes with age Ken, see your GP :Laughing:
    • Like Like x 7
  5. Munchie
    Jul 28, 2007
    8,575
    11,762
    Oi!!! :Angry:
    • Like Like x 2
  6. Popeye
    Popeye Funster
    Sep 5, 2011
    7,806
    17,379
    New Forest
    I think that might be an age thing Ken, I'm not looking forward to it at all.......:Laughing:
    Bugger, Pappajohn beat me too it.......::Doh:
  7. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,823
    And me :Rofl1::Rofl1:
  8. GJH
    Aug 20, 2007
    27,337
    34,823
    Could well be the cause. Our previous van didn't have an auto valve so we're having to get used to it on the Burstner. We have had to run the heating for a short while a couple of times to raise the temperature around the valve sufficiently for it to stay closed.
  9. rangitira
    rangitira Funster
    Jun 30, 2010
    6,324
    12,831
    Cornwall
    Yeh thanks BwB, it was this arvo, and warm, and yes, did have a peg in place, but pump kept working after the system was bled, and water kept exhausting from the system, still thinking of By passing the Valve, until I can get hold of a replacement.
    But it seems slagging yer mate off is the go:Angry:
  10. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    When I 1st used the dump valve, I thought that it was not closing as it kept dropping when I tried to close it by lifting the valve. Eventually realised that I was not pulling the valve up firm enough so gave it a hard pull and it locked into place Could you be experiencing the same problem??? Just a thought, give it a hard pull and see what happens.
    • Like Like x 1
  11. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,384
    Kirby cross further from londin
    Sorry bad taste post removed
    :Eeek::thumb:
  12. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,782
    7,613
    Lincs/Cambs border
    Hi Rangitira,
    If you don't have power to the valve, it will not stay closed at ambient temperatures below 6 degrees C. Turn on the heating but turn the thermostat right down, to prevent the heating coming on, that way, you are only powering the dump valve, and not using any gas
    HTH,
    Jock.
    • Like Like x 1
  13. M1TCH
    M1TCH Read Only Funster
    May 15, 2011
    258
    101
    East Midlands
    Put a hair dryer on it for about 10 seconds it stays up then. so does the dump valve :Wink:
    • Like Like x 1
  14. Munchie
    Jul 28, 2007
    8,575
    11,762
    Didn't bother me. :Smile:
  15. pendy
    pendy Read Only Funster
    Oct 9, 2008
    155
    97
    Birmingham
    Just for information purposes, the new style valve on the Caioca has a tap type lever you need to realign, and then there is a reset button to push!! How do I know, I did mine over the last weekend!! HTH:cry:
    • Like Like x 1
  16. iandsm
    iandsm Funster
    Jan 3, 2008
    1,575
    2,739
    Suffolk
    Dribbles
    We have the Truma C6002 gas and electric boiler with the electronic dump valve. Ours had the "Dribbles" last year and cleaning out the system with vinegar in the hope of removing any lime deposits did not work. I got a replacement from the retail arm of Tuma, which is called Miriad Products. Around £50.00 or so. This cured the problem and was easy to fit DIY.
    Interestingly the electronic valve has now been superceeded by the new non electrical type so I wonder if these things had been giving problems
    • Like Like x 1
  17. rangitira
    rangitira Funster
    Jun 30, 2010
    6,324
    12,831
    Cornwall
    Thanks Fellas some good tips there from you all. Had decided to change the valve from Auto to Manual. But tried the Hair dryer (well paint stripper gun) and it worked
    All power to you all:notworthy::notworthy::thumb:
    • Like Like x 2
  18. M1TCH
    May 15, 2011
    258
    101
    East Midlands
    It worked for me so passed it on glad it helped :thumb: Gray.
    • Like Like x 1
