Attaching the Water Filler Cap to the Van (2 Viewers)
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
Hi All,
In an effort to prevent me;
A. Losing or dropping the Fresh water filler cap or
B Putting it down in a less than savoury place at an Aire Filling Point.
Or a combination of the above
I bought the below plug chain and attached it to the Fresh Water Filling Cap, suitably drilled to accept a key split ring.
I took one 'S' connector off the chain and that left the figure of eight connector that attached to the split ring.
I suitably shortened the chain to about 8" or so and prior to attaching it to the R Fastener I threaded the chain through a short length of narrow plastic tubing to prevent it tapping on the bodywork when in motion. I fastened the chain to the R Fastener by partially slicing through the R Fastener and then drilling a small hole, (slightly smaller than the chains little balls) This allowed me to force the chain through the created slice.
Finally, I screwed the R Fastener through one of the three retaining screws for the filler fitment.
By the way, I didn't buy 100 R Fasteners. I found one in the bitsa box.
Broken Link Removed
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
I don't have a fresh water filler cap . . . . but if I did. (y)
you should have attached it to a chain then you would not have lost it :D:D
we spent an extra night at Braemar last year when we got 30 odd miles away and stopped for lunch realised the cap was not on, which also meant it and the spare set of keys were sat on the wall on site, so returned and stopped another night :D:D
Emmit
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
PS. Forgot to add, the clear plastic tube has a small hole drilled into it at the lowest point so that any accumulated water drips away.
13,079
101,442
Hymer S800
not long enough
The water filler cap on our Hymer has a tether ..
like this one
Firstly apologies @emmitdb for the thread hijack
@ScotJimland I am considering this style of fitting as our water inlet hose on our Hymer suffers from an airlock and blows more water back than goes in sometimes
However, we have no overflow on our tank, do you? Our overflow is back up the fill tube, so we could have a big issue if as I often do walk away and forget I am filling (mainly at home not on sites I would like to add :))
Emmit
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
Off to France tomorrow.
As this add-on is visible, I wonder long before I have to practice my Franglais.?
Teddyj
35
139
St Neots
Since 2009
Fantastic, simple but so effective,job for tomorrow.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
That's nice with some thought for the detail. Someone got a "Top Tip" award in MMM for his version - which had an unprotected chain & a extra screw on the rim to connect it to. Bet he'll be pleased with the bare aluminium look downwind of the filler :D.
Apr 25, 2012
794
826
Near Truro, Cornwall
Maybe they realise that Hymer owners are that bit more forgetful :LOL:;)
Sadly that is all too true. The tether on our van broke, but luckily for me we only ever fill up when on site so when I forget where I put the cap I don't have far to look. But......last year on our tour of Scotland I filled the van up with diesel and when we got to the next site realised I'd left the fuel filler cap behind! When I asked the Hymer dealer how much to replace it, I nearly fell over when they said around £250 for one with a key.....or less than £20 for one without. Guess which one I chose? Might be worth fitting a chain to that one though...
Reactions: GJH
sleep e carr
109
31
Whitby North Yorkshire
Talbot Express 6 birth
Since 1970 first van converted police van
I done the same with my filler cap years ago when I lost the first one and had to pay 8.50 for a replacment
bryandh
1,173
1,406
Malaga, Spain
A Class. FFB Tabbert 570
Since 2010
Have the same horrors about leaving the Thetford cassette cap in an " inappropriate" place and seeing it disappear down the "dunny". Might well adopt your solution.
Bryan
Lenny HB
53,417
149,914
On the coast in West Sussex
Hymer B678 DL
Managed to lock mine in the garage with the keys in it a couple of weeks ago, good job wife had her keys, we were in Greece at the time.
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
I was too careful/careless and locked mine in the belly locker with the key(the same key that fits belly locker!):censored:. Had to make do with a rag stuffed in it until we received the spare key from home sent special delivery to Loch Lomond. Now make sure I don't lock locker until finished filling up.
madgeD
259
480
Cleveland
Van conversion
since 2005
Its easy done if you leave it in the grass when topping up and get distracted :whistle: we didn't notice until we we had travelled 100 mls away !! its not the expense of a new cap thats the problem its the two keys you end up with!!
