Atmosphere Floor Led,s (1 Viewer)
Alonsos
177
15
Devon Somerset border
Auto trail t615
Since 2008
Picked up new Chausson best of 510 today
How do you turn on (atmosphere floor lights) 1/2 dozen blue led,s that illuminate the floor
To you & me when it's dark
Can't find the switch anywhere it's doing my head in !!
It has to easy but can I find it , not in the manual either no ref to it
Thanks you lot take care
Cal54
3,805
62,010
Southport, UK
Leisuredrive Renoir
Since 1996
Can't really help as although I have this lighting it isn't on a Chausson. The switch on my Autocruise is adjacent to the switch above my door for the habitation lights. (Next to my control panel).
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
Thanks still not found it , they were on during the handover , I turned of panel and drove home , on arriving home playing with lights etc to see how it all works dissed it all but can't work floor lights , must be missing something obvious ha !!
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
Thanks ,
Yes your right but by time I got home dealer was closed and thought would ask question on forum it's been a long day and all that .
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
I've got the same but on a different van, on mine it's on the control panel but you can adjust the light output (dimmer) from 0% to 100% from off to full brightness maybe yours is the same
Go to the floor lighting on control panel and try increasing
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
Have dimmer on control panel but it only adjusts panel brightness like the dash instruments on a car
Will ring dealers in morn
Thanks for your reply take care
Jun 16, 2013
1,228
820
Wiltshire
Low Profile Hymer CL 554
Since May 2014
We have a 510 and there should be two switches by the cabin door under the coat hooks. One is main lights and the other atmospheric lights. :)
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
Thanks for that,
Yes I should have posted (fault found) re last ditch effort on my( days old van) I thinks perhaps open circuit ? So removed the switches you mentioned and lo & behold A WIRE OFF , reconnected it & atmosphere lights came on & power returned to bed panel ,ok the bed circuit is fed through a light switch mm! Rather odd me thinks but all ok now
Alan
Reactions: CWH
