ATMB Toll Tag positioning (1 Viewer)
Oct 11, 2016
1,313
2,196
Bognor Regis
Bailey Adamo 69-4
6 years
I now have one of these tags. The instructions say to fix it at the top of the windscreen behind the mirror. However this seems not applicable to a motorhome because of the overhang above which will prevent the sensor reading it. It says to place at the bottom of the windscreen in this case. I'm just curious as to how you others gave managed this.
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Do as it recommends. You will have no problem by sitting it lower down .it needs to see the receiver so the over hang is in the way by fitting it at top of screen
1,037
1,404
Hampshire
Carthago C-Line
Since 2016
Our tag sits in one of the little trays facing the window in the middle of the dashboard - works perfectly there.
Reactions: Pia
Steve N Tracy
1,229
3,720
Southampton
4 Years
Ours is at the bottom, out of the wiper swept area so the mounting won't cause mot issues.
9,762
20,115
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I`ve not got an overhang so it`s behind the mirror
Won`t stop me sweating a bit though first time through the toll with a queue of traffic behind !
Leave for Loire on 24th June
Bognor Saint
Oct 11, 2016
1,313
2,196
Bognor Regis
Bailey Adamo 69-4
6 years
I'll be sweating 2 days before you!
1,037
1,404
Hampshire
Carthago C-Line
Since 2016
We don't have an overhang either (just little bit protruding above the cab - but it doesn't obstruct line of sight for the tag), even so I found when we first tried the tag that it didn't work very well up at the top - it seemed to take a lot longer to be registered by the equipment and activate the barrier. Possibly the issue was that the sensors are aimed at either "lorry height" or "car height" and the top of the MH windscreen is in between the two. It works much better at the bottom of the windscreen - maybe because it mimics the "car height" placement?
awg
302
354
Suffolk, UK
WIldax Altair RS
Since 2015
Please post how you get on !
Used mine for the first time over the Easter weekend.
Slightly worried as I approached the first toll but absolutely no problem. Makes life a lot easier with a right hand drive vehicle. Also had my first invoice which was automatically taken from my Debit Card.
Allan
1,373
3,325
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
I am looking forward to driving towards the barrier at speed (y)
Pia
855
725
staffordshire
Adria Coral Supreme 680ST
don't worry....drive slowly right up to the barrier and it works beautifully..... if somewhat slowly in France....we have both French and Spanish versions...the Spanish one works instantly....whilst our French one takes a second or two to work...but neither have ever let us down in the 4 or 5 years we've used them.
9,762
20,115
Hymer B544 A Class
Since 2015
I can indeed confirm they operate as intended, so much easier than fumbling with change.
Bognor Saint
Oct 11, 2016
1,313
2,196
Bognor Regis
Bailey Adamo 69-4
6 years
Panicked a bit earlier today. Arrived at toll gate and barrier did not raise. Big truck behind so options limited! After about 40 seconds ( seemed longer at the time) it raised. Credit to the truck driver as I thought he would start venting his annoyance.
Pia
855
725
staffordshire
We have found this in France some of the toll barriers are REALLY slow to rise.....but ....in about 5 years we have never had a situation where the barrier has failed to rise...so don't worry...all will be well....the truck driver was patient as I suspect he has similar experiences:D Happy travels.:whistle:
1,373
3,325
Burstner TD700 H L
Since 2008
Mine is working fine..yes some are a little slow...sorry for posting the picture of the wedged cars ..as we saw on Saturday a car and a caravan both took the same lane ..not too much damage :eek:
229
634
Merseyside
Hoping to buy 2016
None whatsoever
We have had one occasion when it didn't work,yesterday!! Waited ages as some do seem to take a while to move but this one hadn't after a few mins and a long queue behind us.In the end got assistance from a Toll employee who finally raised the barrier for us,he couldn't understand why it hadn't worked.
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
I have used Ind for some years in the car, when UK drivers could first have them, you could see some French drivers think, he will never get through the high speed one, how happy were we passing all the French cars queuing on our way down to the Alps for skiing :). I haven't checked to see if we need to re-register or just good to go. Certainly didn't need to change it for the m/c just use the appropriate lane to avoid paying the car rate.
