At the rear
Discussion in 'Motorhome Chat' started by sinbad1, Feb 5, 2009.
  1. sinbad1
    sinbad1 Deleted User
    Not had our motorhome long and only had a few local trips, cant wait for the better weather.
    One thing i have noticed is not being able to see anything at thre rear of the motohome, there is a window at the back ;but this is relativly small and cannot see anything through the rear veiw mirror.
    Whilst the side mirrors are great, very often i can't see anything thats just behind me.
    Do others have the same problem ? and are there any alernatives?
    Regards
  2. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,643
    8,069
    Tropical Bar,Benidorm.
    Do others have the same problem ? .....Yes :Wink:
    and are there any alernatives? ...Yes, have a rear view camera fitted, :Doh:
    bit of an expensive solution though. :BigGrin::BigGrin:
  3. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    Other than the camera suggestion it's a matter of getting used to it - trucks don't have inside mirrors it's all done on the wing mirrors and in the HGV test you have to park with the rear end over a marker about one-yard in depth - the more you use it the easier it becomes - adjust the mirrors and your seating so you get the best view - use your mirrors more often when driving so you are aware what the 'scene' is behind you and wait before turning in case a vehicle or cyclist has moved into your blindspot.
    :Smile:
    Keith
  4. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Drove vans in my youth, no cameras no problem, but I wouldn't be without now on the RV. Picked up a simple Kress & Boll (?) system from Germany via eBay at around £100, sort of thing trucks (that do) use. B&W, works day & night with sound, and as said wouldn't be without.
    Si.
  5. sinbad1
    Thanks got one of those ;but only works in reverse:Eeek:
    I did see this sticker on a lorry once
    [​IMG]
    If you can't see my wing mirrors
    I can't see you
    Think i'll see if i can get one of these:BigGrin:
    Regards
  6. superk
    Aug 22, 2007
    503
    57
    Devon
    It's taking a power feed from the reversing lights. Should be a simple job to rewire so powers up when ignition turned on - with the RV could also be used when ignition turned to accessories or whatever.
    :Smile:
    Keith
  7. Frankie
    Frankie Funster
    Nov 8, 2008
    131
    29
    Buckinghamshire
    Hi,Suggest you google vision uk.wireless reversing camera,monitor replaces rear view mirror,infra red night vision.I fitted one and wired up so that it is on all the time,fitted a switch on camera feed.Quite expensive but very pleased with mine and wouldnt be with out it,:Smile:
  8. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,060
    13,043
    Ramsey, Isle of Man.
    I have driven Artics for more years than l can remember, and have never needed to see through the vehicle. Its just a matter of getting used to the door mirrors. Also, if you think you can see things behind you, you're mistaken, because usually the window is high up and you will not see small or low objects behind you. Reversing using mirrors is easy when you get the hang of it. And as others have said, a rear view camera is a good investment.
  9. sinbad1
    Hey that may be the answer :thumb: If i can find the wiring diagram as the reversing screen is part of a dropdown dvd/digital tv player.
    The cab rear view mirror is a waste of space
    Regards
