At last!!!!
Discussion in 'Motorhome Chat' started by wizzer59, Jun 25, 2011.
  1. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Englishman in Mid Wales
    Hi Guys
    Well we've only gone and done it:party2: put a deposit on our first motorhome a 1998 Peugeot boxer Autosleeper Pescara, in really nice condition with 24,000 on the clock.
    should pick her up next weekend with a bit of luck, can't wait,:wooo::wooo::wooo:
    right everyone what do I do?, what do I need?, where should I go?, how? what? yahoo:shout::shout::shout::rollonfloor::rollonfloor::rollonfloor::rollonfloor:
    • Like it Like it x 2
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,807
    6,321
    South yorks
    Hi Whizzer first thing to do is go out and buy all-sorts of stuff you don't need :BigGrin:
    Make sure it comes with a hook-up cable and gas bottle or two :Wink: After that borrow a few things from the house-bottle opener, plates, mugs, quilt etc and either try it out on the drive or somewhere local ish and enjoy :thumb:
    You will soon be aware of what you need rather than want :Rofl1::Smile:
    terry
  3. normanandsue
    normanandsue Funster
    Dec 31, 2010
    1,376
    5,578
    Dunfermline - Scotland
    Hi and welcome to the wonderful world of Motorhoming. You have bought what I think is the best used van avaialable - our's is the Ravenna in the same range and we have enjoyed every moment we have had her.
    The first thing you should do before accepting your van is to make sure the dealer/owner shows you how everything works and then make sure it does. Turn the hot water heater on, the gas fire on - even if it is a scorching day and try the blow heating system on gas and ehu too
    Work the fridge on ehu, 12v with the engine running and also on gas. It will take time but save you frantic heartache later should something not work.
    Dont forget to test the cooker and the oven and the grill and have them all on at the same time, this will make sure it is working efficiently.
    You will already have checked the habitation report, though on your van this should present no problems, the only place for damp to ingress is the windows.
    The advice from your other posting is absolutely spot on - buy nothing, drive to a pleasant spot and try everything out and then spend a night having a bed and breakfast in it in your driveway, this way you will know what bedding you need and should you decide you need something its a short trip to the house to get it.
    A useful trip I have learned is to try and make everything you carry serve more than one purpose - space is limited and increases in weight increases fuel consumption.
    Have fun and enjoy yourself.
  4. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Hi Guys thanks for that:thumb:, good idea not to go to far, there is a little cl just 2 miles up the road ideal for testing her out, its a private sale and its not coming with gas bottles as the guy is going to get a caravan, so any idea what the max size bottles I can put in there?
  5. normanandsue
    Dec 31, 2010
    1,376
    5,578
    I can carry 2 x 7kg bottles but unless you are going abroad I would not carry two bottles about - too much weight and replacements are easily available.
    Ask around your friends and see if anyone has an empty bottle sitting in their garage they would let you have, then you will only have to pay for the refill.
    Ask the guy if you can borrow one of his bottles to test out the gas supply.
    If you haven't had the gas supply in your MH tested then I would recommend getting it tested. Gas leaks and MHs don't go well together.
    Norman
  6. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Hi Norman
    Thanks for that, I am thinking about LPG in the future, so one bottle will do me for now and Ill take your advice and ask around.
    The only thing that worries me, is the 1.9 engine man enough?, which reminds me, do you know what the payload is on these vans?
    Tim
  7. normanandsue
    Dec 31, 2010
    1,376
    5,578
    Tim,
    Depends what you mean by man enough! You mention a 1.9 so I am supposing your MH is a diesel, whilst mine is a 2L petrol with lpg conversion. It does not run like a car but few MHs will but it will cruise quite nicely at 60 mph and take most hills in 5th gear. Really steep ones with no run at it will probably require a gear change but I think it will be enough. But if you have bought the MH then you will have to make the best of what you've got. Having spoken to a few MHers their advice is buy the biggest engine you can afford, suggesting the bigger the engine the fewer gear changes and the better the fuel consumption.
    Not being a techie I am not sure quite what you mean by payload, does it not say in the Peugeot manual? If not someone on the site will know
    Just out of interest why are you looking towards lpg.
    Norman
  8. Gran & Rog
    Gran & Rog Funster
    Apr 17, 2011
    1,105
    269
    Lofthouse, Wakefield
    Hope you enjoy your new Motorhome and spend many happy miles in her:thumb:
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Hi and well done about time you got a van you have been lurking long enough, hee hee. There should be a weight plate under the bonnet, which will have GVW gross vehicle weight. Subtract your actual weight from that and you have your payload figure but do make sure individual axle weights are not exceeded. do make sure he uses his gas bottle to demonstrate everything working including the fridge (approx £700 to replace). If possible video the demo so you can refer back to find out how things work. What all the switches do etc. Check the engine compartment and make sure the scuttle kit has been fitted, not sure what date that stopped being a problem.
  10. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Hi Norman
    Thanks for all that, Im looking at LPG for heating and cooking simply for cost and convenience realy and if I put in a tank underneath it will free up the gas locker for other stuff. being a pretty practical bloke I think I can do it pretty cheaply by sourcing all the bits and doing it myself, I will of course get it checked by a proper gas tecy bloke afterwords.:thumb:
    Tim
  11. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Hi Wildman
    :BigGrin:Yes you are right but I have enjoyed lurking and learned plenty doing it, thanks for advice on payload looks like Ill have to take a trip to a weighbridge.
    I remember something about the scuttle thingy, i have to look that up too:thumb:
    Tim
  12. TonyMH
    TonyMH Read Only Funster
    Oct 11, 2010
    16
    Epsom Surrey
    I bought a 7 kg gas bottle on Ebay for a fiver - only a few miles from me. A bit old and tatty but that doesn't matter as you exchange it straight away for refill. Refills cost around £21 I have found but it pays to shop around. Good advice re. 1 bottle in the UK, but take 2 if you go abroad...they are weighty. I also take a small portable gas stove so that I can cook outdoors and you can get the small gas bottles for those anywhere - also saves using your main gas supply if you think it's getting low. Enjoy your Peugeot :Laughing::Laughing::thumb:
  13. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,034
    2,811
    Hi Tony
    Thanks for that, Im checking ebay as we speak:thumb:
    Tim
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,807
    6,321
    South yorks
    Hi Tim always worth checking your local dump-it site for bottles -any size - you should be able to exchange it for the right size :thumb: although 6kg are scarce
    terry
