As the sun is shining, how do you check if solar is working? (1 Viewer)
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
Thanks for all the replies yesterday.
My MH has one solar panel on the roof, the salesman didn`t know much about it and it wasn`t mentioned as far as I can remember at the handover. Is there a way to.....
a) Find out what size it is and
b) Check whether it is working.
There are two leisure batteries fitted, one being an extra we had thrown in as part of the deal.
Steve
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Is there a solar panel picture on a control panel in the motorhome? Mine has a list of pictures ( leisure battery, engine battery, waste water level, fresh water level, solar panel & outside temperature) If it has, press the bit next to the solar panel & it tells you how charged it is. Mine was reading 90 (I take that to mean % but I might be wrong!) yesterday. The 2 batteries each read 98. So I'm reckoning that means the solar is charging the batteries & I hope I'm right.:winky:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
The one sure way, make sure no mains charger on, voltmeter across battery, if it's over 12.5V it's charging. If it's over 13V it's charging well. If it's over 14.6V it's about to die ( faulty solar regulator ).
There should be a charging LED on a solar regulator somewhere.
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, did not see anything on the control panel that made me think solar when I went through the sequence a few times yesterday, will take another look.
I don`t suppose a Solar Regulator would happen to have those words or even the word Solar on it would it? I doubt it will be that simple... ::bigsmile:
Is a voltmeter something I need to get and learn how to use?
Thanks for the replies, I will go take a proper look and report back later.
Steve
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Steve
Yes. Very much so. Cost ÂŁ10 max.
Very easy to use. Just click to a range of 24V DC or 200V DC depending on what is on offer. Stick one probe on each battery terminal. It may read 12V or it may read -12V which just means you have to probes the wrong way round.
It's the only 100% sure way of knowing exactly what is going on.
Solar regulator is a problem, if an aftermarket fit is would be a small box ( couple of cigarette packets ), but if part of a full control until it could be built in to a control panel somewhere. Hence the One True Way, the voltmeter.
Here is one that would do and you would click to the "20" at 10 o'clock.
Link Removed
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
And there's the difference in experience!!!! I rely on pictures & Hilldweller has the technical knowledge. I shall now learn how to use a volt thingy.
Encantador
Jul 2, 2011
953
492
UK
Newbie
Can I ask what I am supposed to be seeing on the control panel when on EHU?
It says hab battery 13v cab battery 12.v and I think it is saying 1.25a is `leaving` the hab battery. Lights an heating are on and elh connected.
I think yesterday when on ehu it showed a charge going `into` the hab battery.
Does this look normal?
Steve
43,323
49,428
Steve
sounds about right Steve, depending on the size of your charger and the power being used, you may just be taking out slightly more than the charger is putting in.... hence the 1.25a drain
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, nice to know.
Still no idea on whether the solar is even connected let alone working, beautiful sunny day today.
43,323
49,428
thats why you really need a voltage tester/multi meter.
one way that might give an indication......
unplug hookup, turn on the heating and check voltage on your panel meter, get on the roof and completely cover the solar panel (old blanket or cardboard should do it) and check the voltage again...if its working the voltage should be slightly lower with the panel covered.
even on a bright sunny winters day you wont get much from the panel as the sun is too low in the sky
Nov 23, 2011
479
405
durham
Lowline
since 2006
If cab battery is only 12volts it seems a bit low. Usually swift motorhome are able to charge the cab battery on EHU. To do this select the cab battery on the control panel and see if cab battery voltage charges to a higher voltage of around 13 volts.::bigsmile:
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, there is a seperate button on the control panel with a picture of a cab, it is the only switch with it`s own red light, when pressed the red light comes on and the display looks as though power is leaving the hab battery at a rate of knotts, I turned it off quick... ::bigsmile:
I assumed when on EHU with just lights and heating on there would be more than enough power without draining the hab battery as seemed to be happening earlier (see earlier post). It`s certainly a learning curve....
Steve
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I would have a look on the roof and see where the cables go through and then follow them on the inside :thumb: then report back
