Are corner steadies safe in an electrical storm (1 Viewer)
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Just reading another post on corner steadies and it reminded me of something I have thought about on odd occasions. It is well know that a car stood on tyres is a very safe place due to the Faraday cage effect, now if you put two metal jacks down onto the ground is this negated and the van more at risk.
Feb 27, 2011
14,731
75,856
UK
Self Build
Perfectly safe. As with all storms though don't get in or out of your van during the storm...:xsurprised:
:xeek:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
The Faraday principal does not rely on your rubber tyres Alan but on the fact that you are encased in a steel box, which in the case of a MH it is not a steel box so I cannot see the same principal applies.
Bertie Bassett
2,743
8,702
since 1988
Never thought about it,should have though, I'm going to follow this thread with interest. Thanks for posting L.:xThumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Mine have thick mahogany insulators :p
Badknee
7,407
412,505
notloB
Vantage Neo
Living the dream.
What about if you put them on wooden blocks or plastic feet?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Why do you think they put lightning conductors on tall buildings?
Creating a path to earth for the voltage should reduce the damage to the structure in the event
Badknee
7,407
412,505
notloB
Vantage Neo
Living the dream.
Paul, the lightning has probably just jumped several thousand feet.. I doubt a couple of inches of anything would be a whole lot of help ! :xwink:
Just a thought John, mind you I don't know why I bothered we don't use ours at all. :xrofl:
Feb 27, 2011
14,731
75,856
UK
Self Build
We always park next to someone with a sat dish they are always higher than us so any strike should get them first LOL.
Lightening doesn't always hit the highest point or the sharpest point. I saw a video recently regarding this but can't remember where...
Dec 24, 2009
1,072
15,707
bedworth warks
c class
2009 previously a tugger for thirty years
Well that's another theory out the window then! thanks Gromett (not) I will just have to rely on the old faraday principal.
Just as an aside we were in a few very heavy thunderstorms in the south of France this year they were shaking the van a bit!
Jaws
23,834
72,435
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I spose you could always rip out the insides of your van install a complete covering of wire mesh and then reinstall everything ..
That would certainly work as a Faraday cage !
Welsh girl
3,658
3,036
Globecar
Since 2004
I have also thought about this, what about the ehu cable.
When at home I always pulled the plug out of the back of the TV when an electrical storm happened.
I've heard about lightening hitting the aerial and setting the house on fire.
Also when the satellite dish is on a tripod outside, do we need to disconnect the satellite cable while the storm is happening?
I've always said we're not in a Faraday cage, we're in a wooden one.
Jaws
23,834
72,435
Thetford Norfolk
C class, Chieftain
Just a personal thing, but years ago I gave up disconnecting thins
From 1970(ish ) to 1980(ish) I ran a television aerial installation company..
In those 10 years we had one call out to a place that had taken a strike..
While it did the tv no favours, it was the chimney that took the brunt, blowing it in small pieces across three gardens !
As an unrelated factoid, apparently you are 8 times more likely to be struck by a meteorite and 3 times more likely to be struck by lightning than having a BIG win on the lottery..
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Driving a MH in lightning is the same as a Reliant Robin, Sod all protection, it would go through it.
I have been hit in my car on the M2, , big flash, huge noise, no damage to see, everything still worked even the ECU, just as well I was going to fly out of Gatwick a couple of hours later. The bloke following got a bigger shock than I did. He could see well for a few minutes.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I always wondered about this with our narrowboat, in effect a steel box in water. Have never been able to find a case in over 25 years of a boat being hit, however, I do remember hearing of a guy with a brolly mounted to the roof. The brolly took a hit, as did the paintwork of the boat, but all occupants and electronics were fine. Possibly the Faraday Cage principle.
