Aquastar for descaling Truma Combi (1 Viewer)
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Planning to descale/debug the Truma Combi 6E with Aquastar 1+2 (got a packet cheap) and at the back of my mind is something about heating the water up to 70C to maximise efficacy of the chemicals. However in the Truma manual under the heading of 'Maintenance' it says: 'The effectiveness of the use of chemicals to combat micro-organisms in the unit can be increased by heating the water in the boiler to 70C at regular intervals.'
Aquastar 2 is the chemical that deals with micro-organisms and has to be left in the system for 12 hours. However the manual that came with the Aquastar pack makes no mention of heating the boiler up at all (the chemicals are to be mixed in warm water). So does the phrase 'at regular intervals' refer to heating the boiler to 70C during those 12 hours? In other words, should I heat the boiler up with the chemicals in it or not? I can find no mention of this on the Truma website and don't want to potentially damage the boiler by heating the chemicals up in it if they are not supposed to be heated.
Does anyone know the answer? All thoughts gratefully received. :Smile:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I think all it is saying is that fairly regular heating of the water to 70 degrees C will help keep micro-organisms at bay...
Reactions: maz
maz
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Thanks Popeye. I did wonder if that was all it meant but the mention of the 'effectiveness of the use of chemicals' made me think it might be to do with when the chemicals are actually in the system before being flushed out again.
Lenny HB
53,309
149,501
On the coast in West Sussex
Hymer B678 DL
Did mine a couple of days ago, used 2½ Lt of white wine vinegar (as recommended by Truma) after filling the boiler I set it to 60 deg and left it for 3 hours & then flushed it out using all the taps.
Total cost 60p.:)
