Aqua 8 won't stop pumping
Discussion in 'Tech/Mech General' started by laser101uk, Apr 18, 2015.
  1. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    848
    Basingstoke
    Hi. my aqua 8 pump was making a lot of noise all of a sudden so I went and bought a new one today and fitted it. fitting was very simple i turned on the pump and it worked. taps worked etc, but.....it won't stop. its seems the in built pressure switch isn't turning it off. I tried adding more air pressure to the fiamma a20 universal expansion tank and then the pump stopped. Thats it I thought, but no. I turned the tap on and at first lots of pressure, then the pump kicks in and the pressure drops and the pump just keeps going and going and going long after i turn off the tap.. The old pump was an identical model and was working fine, the problem was it started making a lot of noise, and suddenly started sounding very unhealthy but it held the pressure and turned off automatically.
    I am guessing it has somthing to do with the pressure, but I don't understand how the pump can keep going and going yet when I add pressure to the expansions tank it stops, it seems i then lose the pressure when i turn on the tap. Never had a problem before the old pump always turned off a few seconds after the tap was turned off. This new pump seems to push a less pressure, but i thought that was what the expansion tank is for?
    any ideas please?
    cheers Steve
  2. BwB
    BwB Funster Life Member
    Apr 3, 2011
    607
    563
    Brandon Suffolk UK
    Im guessing youve checked there are no taps open, leaks or the frost valve on the water heater hasn't opened?
    Othere than that, is the new pump rated at the same pressure as the old one? Even same models can vary on pressure depending on which one youve ordered.
  3. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    848
    Basingstoke
    Just re fitted the old one and it works perfectly, apart from the horrible noise its developed, but in the pressure and switching off properly its fine. I'll check the pressure rating but its literally the same pump.
    thanks
    Steve
  4. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,218
    891
    Isle of Sheppy
    Is it a pressure pump or are the taps fitted with micro switches? Could just be a tap not working.
    Joe
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    Then that points to a faulty new pump....no offense, but its not exactly rocket science
  6. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,358
    1,443
    Suffolk
    I wonder if it is air in the system??-----I would re-bleed it ALL and see if that makes a difference
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,335
    5,344
    East Sussex 01-580-881288
    Check the pressure switch, they are adjustable
    Peter
  8. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    848
    Basingstoke
    Is the pressure switch adjustment the small allen key screw underneath the pump?
    cheers Steve
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    if it is an adjustable pressure switch there should be instructions in the box. One would think
  10. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    848
    Basingstoke
    I'm not sure it is adjustable, there's nothing in the instructions about adjusting, says its an automatic pressure switch.
