Apple TV
Discussion in 'Motorhome Chat' started by Dogsense, Mar 13, 2015.
  1. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Good morning good people - help Please
    Can Apple TV work on 12V, if yes -how, if no - any solution?
  2. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,801
    No.......... but maybe with an invertor?
  3. brynric
    brynric Funster
    Sep 5, 2009
    340
    316
    Worcestershire
    Solution? It depends what you want to do. We have a lead to mirror the content of the iPad/phones through the tv.
  4. Chockswahay
    May 29, 2012
    3,097
    4,801
    I assume @Dogsense is interested in the content that Apple TV can provide (which is a lot(y)). It would require a quality invertor ....... http://sterling-power.com/products/pro-power-sb-pure-sine-wave-inverters?variant=891674727
    The Apple TV would only draw half an amp from the battery so a low powered invertor would do the job. I have an earlier version of the 300w model that has always performed faultlessly with high tech equipment.
    Of course you will need a separate internet source.........
  5. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    We would like to watch mainly Films from sites as MovieTube, our pictures and videos receiving from family, Skygo, BBC iPlayer, BTsport etc.
    I need investor, would like to have one that would be right for charging EBikes Batteries and sometimes hair drier ...
    Which one recommending?
  6. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    Inverters are rated by wattage.. so whatever you plan to use requires an inverter with the wattage of the appliance plus about 20%..
    to work out just how much each uses.. look at the data plate for the watts or wattage..
    the formula is watts/voltage = amps,.. so divide this number by 12 to get the current drawn.. so for every 100 watts you will be drawing about 8.5 amps from the leisure battery
    but it's a dad idea to use the leisure battery to charge ebike batteries, it will soon be flat.. likewise a hairdrier.. unless you have a big battery bank and a method of recharging ..
  7. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Thanks ScotJimland.
    I think I mixed 2 inverteres:
    One to charge Apple TV, Hair dryer, phones etc srom 12V socket.
    One for carging Ebikes batteries while driving, from van battery.
    Wate the recommendations please.
  8. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    Ok .. for the Apple tv.. you need a pure sine wave, and I think the smallest they make is 150 watt.. this one from Maplins would do the trick http://www.maplin.co.uk/p/maplin-12v-pure-sinewave-150w-inverter-a71jw
    Do you know the wattage of the ebike charger ?
  9. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Not yet, need to chose and buy them first LOL
  10. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    ah ok.. another member may be able to help with that .. but you may find 150 watt inverter can do both jobs.
  11. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    6,025
    12,197
    Kettering
    Not sure how many of these will work outside the UK or whether that matters to you and I know that SkyGo at least won't work if you connect TV or other external display to your mobile device.
  12. RichardB
    RichardB Funster
    Oct 19, 2013
    219
    109
    East Yorkshire
    Hi. If you can solder and don't mind opening up the Apple Tv then it can be converted to run off 12v. The actual device only needs 3.4v, so you just need to remove the 240v power supply, fit a 12v to 3.4v convertor and you can hook it straight to the 12v supply in the van.
    I did mine - it cost £5 for the parts and works perfectly.
    There are some instructions on the web from another guy who did it:
    http://i-marineapps.blogspot.co.uk/2014/04/appletv-5-volt-usb-conversion.html
    Richard
Similar Threads
  1. Silver-Fox
    3
    272
  2. Mac Man
    10
    363
  3. Norfolk Red
    39
    1,300
  4. colyboy
    3
    556
  5. Timcropp
    304
