andy63
No need for sorry but thanks..I didn't realise you did the original install sorry.
If there is no room to get a spanner in, then I would probably still go for the wall mounted fuse box. Then use either quick release battery terminals or use something like anderson connectors.
If there isn't even enough room to get a spanner in then it is AT fault for badly designed battery storage area.
The batteries were already on van in the fashion I've described above..
I only installed the solar charge wires and a battery master..
But as I've said only way I could get at batteries was to remove from locker and the auto trail wiring allowed for that... and I made sure my wiring allowed the same thing..
So while it may look a mess I'm happy it's safe and works fine.. it has for nearly 2 yrs with no problems.. that's most probably the first time they have been out since I put them in after doing the job..
Andy
