Anyone like puzzles? Unravel please
Discussion in 'Tech/Mech General' started by irnbru, Sep 19, 2016.
  1. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,677
    10,565
    Glasgow
    Is this double wired in places? Can 2 wires be removed and used to add another 2 batteries?Can anyone follow the wiring.
    And what is the sensor for that's just sitting on top ofthe right hand battery...it's not attached to battery?
    Vehicle is AT.
  2. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,356
    UK
    I can't answer your question. However my first job on that would be to rewire properly and put a proper distribution block/board in place.
    Some of the positive wires don't appear to be fused. It's a bit of a mess?
    • Like Like x 2
  3. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,591
    11,491
    Kettering
    I'm with @Gromett on this. Even if I could see an answer I wouldn't offer it.
    Lashing up something onto previous multiple lash ups always ends in tears eventually.
    It all needs ripping out and redoing properly by someone who knows what they're doing.
    • Like Like x 1
  4. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,049
    3,107
    Rural South West Wales.
    Looks like a monkey puzzle tree :D
    • Like Like x 2
  5. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    I had something similar with my Autotrail, although not as muddled as this and solved it with these multiple connectors from China. A Lot neater now and more secure. The auto connectors I had factory fitted worked loose with vibration.
    • Like Like x 5
  6. hilldweller
    Dec 5, 2008
    26,906
    25,760
    Macclesfield
    I don't know which is worse, your photo what is technically known as A Rat's Nest.
    You need to pick up some wires and photo from different angles.
    • Like Like x 1
  7. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,697
    11,843
    Plympton, Devon
    Notwithstanding the above comments, trying to make sense of it the two negative terminals seem to be connected together and then a single thick black cable comes off the negative terminal in the top right and then disappears into the battery compartment. So far so good but the positive terminals don't seem to be connected the same way. It looks as if each has a separate cable running off into the vehicle. Both of these cables seem to be fused. You can see one fuse on the extreme right, yellow inside a clear cover. The other is a different design and is hidden under some cables at the front. The fuse is red and should have a rubber cover but that is not fitted but you can see it connected to the fuse. There is nothing wrong with each positive having its own fuse and cable - this is how mine is wired.
    If you wanted to add two more batteries then a quick and dirty solution would be to add one in parallel to each of the existing batteries using as short and thick cable as you can. Some might say you should fit a fuse in these cables and for safety you probably should, say 100A.
    As suggested getting it all sorted out by a good vehicle electrician would be the ideal answer - there is a risk of fire in that lot I think.
    The sensor might be a temperature sensor for the battery charger.
    • Like Like x 2
    • Useful Useful x 1
  8. andy63
    andy63 Funster
    Jan 19, 2014
    1,979
    7,236
    south shields
    Hey that's my wiring... :LOL:
    First things first.. a lot of what you see is auto trails own wiring.. the heavier black wires are paralleling the batteries at source and connecting a solar charge controller to the parallel batteries..
    It's untidy looking because in order to be abe to lift the batteries individually out of the locker and still remain connected the wires are long enough to allow that.. there is also a relay to trickle charge the start battery in there somewhere:LOL:
    Andy..
    • Funny Funny x 2
  9. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,356
    UK
    I would have installed a fuse block inside the locker and then had well secured but single wires going to the batteries. I don't like lifting out batteries that are still connected and if I planned on doing this a lot I would have used quick release battery terminals.
    • Like Like x 1
  10. andy63
    andy63 Funster
    Jan 19, 2014
    1,979
    7,236
    south shields
    I might have as well lol ..if I had had the gear.. but I took all i thought I would need to do a few jobs for Sandra .. and had no idea that auto trail would install their batteries in the way they do.
    There's things which could have been done differently to make it tidier..but anyone who knows the set up on that auto trail will know there is no room around the batteries .. and the only way of getting at them is to remove them..
    So anything that's connected to them has to be long enough to allow that.. even auto trails own wiring (the lightweight loops of wire in front of the batteries in the photo allows that....
    The job was a case of having to make do with what I had at time..
    And I don't believe there was any fire risk or safety issues from my wiring... it was more substancial than autotrails.. . It's been in that locker for getting on for two years without seeing the light of day and working fine as far as I know... I'm sure Sandra would have told me if there had been a problem..
    Andy..
    • Like Like x 2
  11. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    between this and jaws thread i dont think i would let autotrail wire a plug
    • Like Like x 1
  12. irnbru
    Jun 27, 2013
    5,677
    10,565
    Glasgow
    So did you say you did or did notify the sensor. Whats it for? It leads to somewhere inside the van and is NOT connected to a battery.
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    Apart from spending an hour or two sorting out the spaghetti you dont need to remove any wires to fit another battery.
    In fact you need two more wires.
    One each from pos and neg of one existing battery to pos and neg of the new one. ...neg to neg, pos to pos.
    But until that mess is sorted out i wouldnt bother.
    The sensor may be a battery temperature sensor for an intelligent charger...in hot weather it reduces charge as the battery is hot and increases in winter when the battery is cold.
    • Thanks Thanks x 1
  14. NickNic
    Jan 14, 2014
    5,591
    11,491
    Kettering
    I was just thinking that Autotrail were having a bad time of it at the moment. There's this thread, Jaws' one and of course matey who seems to find a wet AT whenever he turns around.
    • Funny Funny x 3
  15. rb62
    rb62 Funster
    Nov 5, 2013
    442
    6,076
    Shropshire
    The two looms with the in line fuses are the AT looms,the temperature sensor is connected to the Sargent unit,something to do with charging current?...the rest not a clue :LOL:
    • Like Like x 1
  16. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    They are David...just hard to see.
    Took me a while to find the pos link.
    • Like Like x 1
  17. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    I would have installed both batteries the same way round to keep the link wires as short as possible...straight over the batteries from post to post.
  18. andy63
    andy63 Funster
    Jan 19, 2014
    1,979
    7,236
    south shields
    No idea what that is for... but I did suggest a temperature sensor..
    Now start telling folk what a good job I did .. I need a little support here.. your photo doesnt show the batteries in the locker and the total lack of space ..if I remember correctly you can barley get your hand in to the top of the batteries... so before im hung out to dry some support please..:LOL:
    • Like Like x 3
    • Funny Funny x 1
  19. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    And of course, it was dark at the time. :LOL:
    • Funny Funny x 3
  20. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    I bet Andy (Techno) is sitting quietly in a dark room holding his head. :LOL:
    • Funny Funny x 5
    • Informative Informative x 1
