Anyone know where these can be purchased ?
Discussion in 'Motorhome Chat' started by Kool Kroozer, Feb 29, 2016.
  1. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,182
    1,948
    Cannock Staffordshire
    What are they called and where can you buy them ?
  2. Lofty1
    Lofty1 Funster
    Oct 7, 2015
    169
    459
    newark
    Hi they are called ringbolts you can get them from most marine stores
    • Thanks Thanks x 1
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,150
    3,573
    walthamstow east london
    lifting eyes last ones i got from e bay
    • Thanks Thanks x 1
  4. StanandShirley
    StanandShirley Funster
    Apr 29, 2014
    159
    199
    Chatteris Cambridgeshire
    They can be bought from Cromwell Tools or Buck and Hickman. Both supply to engineering firms. Look on the net to find local outlets to you.
    • Thanks Thanks x 1
  5. mariner
    mariner Funster Life Member
    Nov 21, 2013
    1,284
    3,798
    Isle of Dogs, but mostly Artola Spain.
    • Thanks Thanks x 1
  6. buttons
    buttons Funster
    Aug 27, 2009
    13,604
    11,260
    Hertfordshire
    That dosen't look a very strong base to take a ring bolt they can take a lot of pull.
  7. maxsdad
    maxsdad Funster
    Oct 5, 2009
    298
    234
    anglesey
    Brownhills sell them in their Hymer stores look very similar base slightly different
    • Thanks Thanks x 1
  8. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,091
    1,221
    Dronfield - Derbyshire
    They do seem a bit hefty for that rail.
    Also the base plate its screwed into will have to fabricated and a thread tapped into it.
    I can make you some if you let me have the size and the thread size.
    • Like Like x 1
    • Thanks Thanks x 1
  9. Detnor
    Detnor Funster
    May 12, 2011
    548
    494
    You have 2 components, the ring bolt on the outside, fairly common and probably an 8mm thread.
    There is a 'T' bolt assembly that slides into the rail that you can tighten into the position on the rail you want it and leaves a length of thread protruding that you can screw the eyelet onto. As with many things, the rail can be proprietary and can have an unusual backplate. Google 'halfen bolts' to give you an idea. You really need the profile maker or to look at an existing bolt to see if there is anything stamped on it.
    I got into trouble at the MoD as I produced a drawing with this system and referred to the T bolt as a 'protruding male stud' technically correct but considered unnacceptable!
    • Like Like x 1
    • Thanks Thanks x 1
    • Funny Funny x 1
  10. FM02MZO
    FM02MZO Funster
    Jun 22, 2012
    167
    28
    Castle Donington
    We got ours from Camper Uk in Lincoln
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,576
    10,003
    many trailer shops sell them as sliding load restraints
    • Informative Informative x 1
  12. missmollie
    missmollie Funster
    Jul 30, 2008
    8
    7
    Warrington
    They are a Fiamma part look on line, I have them in the garage of my Knaus.
  13. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
  14. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,002
    11,435
    E Yorks
  15. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,600
    2,584
    Tunbridge Wells
    Need to be a bit careful here. The Fiamma ones are designed for the Faimma rails, but there are others. For example my Hymer uses the Halfen fittings that are shown on Techno's post. They are different and I do not know if each will fit the other. The ring bit is the same but the bit that fits into the rail is different.
