Anyone know what lights these are ?
Discussion in 'Motorhome Chat' started by BusyBuilder, Feb 5, 2016.
  1. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    183
    98
    Cromarty
    They are in my Hymer 552CL.
    I would like to swap them for LEDs but can't get them out of their holder if indeed they actually do come apart.
    pictures show light hanging out of cupboard, in cupboard and one in the skylight
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,941
    West Norfolk
    Looks like a G4 bulb inside.
  3. Detnor
    Detnor Funster
    May 12, 2011
    547
    493
    Look the same as mine. The outside holder remains in place in the locker, the inner ring pulls out releasing the lens and gives access to bulb.
  4. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,768
    11,826
    Kettering
    What they said. (y)
    The lens does come out but they can be bloody fiddly until you get the knack.
    • Like Like x 1
  5. The Wino
    The Wino Funster
    Mar 23, 2012
    1,192
    2,202
    leicester
    Easiest to use a very small screwdriver and work around the edge of the rim to prise the metal ring out (it will unfortunately probably scratch the ring a bit)
    Good news is that the led should then last ages be carefull to get one thin enough for the cover to fit on and try to get one which works with both polarites as if its flat and onl works one way it could be akward.
  6. BusyBuilder
    BusyBuilder Funster
    Jan 31, 2016
    183
    98
    Cromarty
    Thanks for your help, I've emailed Aten lighting as well.
  7. scotzsue
    scotzsue Funster
    Apr 11, 2015
    900
    859
    hull
    Did all ours, holding ring flicks out when you put end of small screwdriver in the cut out bit you can see on the last photo, the first one was a bit like how Ian the builder was feeling this morning but really easy once you get the hang of it.
  8. movan
    movan Funster Life Member
    Dec 2, 2009
    13,626
    24,620
    Moving around
    I ended up having to wait for a meet with Funsters to ask for help getting mine out. It took them ages too .... really, really fiddly .. I'm sure they could have made easier access. :(
