Anyone fitted a roof vent spoiler to stop vibration?
Discussion in 'Tech/Mech General' started by kaspian, Jun 19, 2010.
  1. kaspian
    kaspian Read Only Funster
    Aug 16, 2009
    24
    bonnie Scotland
    Hi all, our new Autoquest 130 has a very annoying habit of when hitting any speed over 50mph , the roof vent cover adjacent to the wardrobe starts to vibrate which sounds like someone using a pneumatic drill on the roof to the point you cannot hear each other talking in the cab because of the racket! Any sort of cross wind can also start it off and it really is so loud it sounds like the cast of Riverdance performing on the roof!:Eeek:
    It has been supplied with the new style roof vent which ,when the internal flyscreen is opened ,the roller blind swings down with it as it is moulded into the same assembly . Our previous 2 vans had the older style hinged removable flyscreen frame .
    Unfortunately the outer opaque vent cover is made from extremely flimsy plastic, the thickness of an egg box and is very poorly held to the roof vent frame ! So far we have travelled with dishclothes etc stuffed into it to try to deaden the racket and Elddis to their credit did offer to change out the vent to the older style but this would involve a 120 mile round trip to a dealer.
    I spotted a Fiamma roof vent spoiler available on the internet that fits around the vent and is supposed to redirect the airflow over the roof vent to stop buffeting . Has anyone fitted such a vent and if so did it work as this would be an easier solution than ripping out the existing vent. Many thanks!
  2. DiscoDave
    DiscoDave Read Only Funster
    Apr 25, 2010
    18
    The north
    I have fitted a Fiamma wind deflector, admittedly not to stop the wind noise on a roof vent but to stop the inane whistling sound caused by my solar panel being on the highest part of the roof. It worked a treat
    One thing i would advise is that the instructions for fitting say to take out the screws on the roof vent and slide the wind deflector under the vent fixings. I would order a deflector of the next size up from the roof vent i was fitting it to, this way the deflector can just be bonded with skia or purflex without disturbing the vent and causing any problems with waranty.
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,172
    16,633
    Liverpool.
    I fitted the Fiama wind deflecters on an old Elddis we had years ago and they worked,agree with previous post...stick them on with Sikaflex.
    What I did find also was that since fitting them I could leave the vents open slightly to aid ventilation whilst traveling without having to put up with the noise.
  4. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
    Hi,
    I know this may sound strange but have you had your wheel balancing checked, I think it may be worth having done before fitting any additional equipment as it could just be a transfer from the wheel balancing to the weakest point.
    The reason I suggest it is that you link this directly to speed, and if it were wind, while speed does have a contributor factor on the wind its not the only thing as wind direction and the general wind speed itself will also play a part, therefore if it happens as soon as you reach a specific speed i would suggest its more likely to be wheel balancing that perhaps you are not noticing via your steering wheel.
    Just a thought, hope it helps
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Hi I made my own from plastic architrave :thumb: stuck to roof with Sikaflex type glue :thumb: When we made it we did not know they sold things like it. :Rofl1: Just looked at the vent on the roof and thought it should have something to deflect the wind :thumb::Rofl1:
    terry
  6. georgio
    georgio Read Only Funster
    Jun 4, 2010
    33
    Afternoon all,
    I put one on the roof of my adria twin to reduce wind noise.
    Ued two fiamma joined together and stuck on with sikaflex and then painted to match, more expensive than first anticipated but what the heck.
    georgio
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,259
    5,240
    East Sussex 01-580-881288
