Anyone fitted a FIAMMA awning rain guard ?
Discussion in 'Motorhome Chat' started by Geordies, Jan 26, 2016.
  1. Geordies
    Geordies Funster
    May 29, 2013
    944
    2,139
    Tyneside
  2. DiggerJon
    DiggerJon Funster
    Jan 25, 2013
    583
    4,851
    Dorchester, Dorset
    I've had one on my MH for four years now and until now had forgotten it was there! I remember that warming it in hot water first made it more pliable to fit, but it only took about 10 minutes to do and is still there. I looked, and it still is there, and does a brilliant job of stopping water flowing in between the gap and subsequently into the awning. Maybe it was expensive, but believe me, the quality is long remembered when the price is soon forgotten!!
  3. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,439
    25,441
    Planet Zog
    Yes, due to the shape of the van, the cassette stands slightly proud of the van so I had to fit one in the upper rear channel at the back of the cassette (yes, it is there for that purpose. Lubricate the channel when fitting and simply pull it in. Friction keeps it there and it works very well indeed. If you need pictures then send me a PM. Cheers!
  4. Dorwyn
    Dorwyn Funster
    Aug 19, 2013
    567
    309
    somerset
    Me too, it's really been good, it's been on there for 4 years, stops the dribble staining on the van sides underneath the awning, too.
  5. jaygee
    jaygee Funster
    Mar 21, 2009
    1,168
    721
    Harwich, Essex
    Yep, had a gap between body and awning where rain dripped through, mine was the strip that fitted above the awning tight fit so used a touch of washing up liquid, still there 3 years on
    • Like Like x 1
  6. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
    Been considering this for a while now and as we are heading to UK in March will have a look at price and get some, sounds just the job.
  7. hilldweller
    Dec 5, 2008
    26,898
    25,747
    Macclesfield
    Why not a use silicon gunge ?
  8. DuxDeluxe
    Jul 10, 2008
    9,439
    25,441
    Planet Zog
    Depends on the gap.... The strip was cheaper and easier than trying to fill a 2cm gap ;)
    Good point for an awning tight against the van wall, but neater if applied to the top where it is out of sight
  9. hilldweller
    Dec 5, 2008
    26,898
    25,747
    Macclesfield
    I saw "bottom" on ebay, plain daft, the back would fill with water and test the bolt hole sealing to it's limits.
    • Like Like x 1
  10. DuxDeluxe
    Jul 10, 2008
    9,439
    25,441
    Planet Zog
    Yes, the cassette had a slot at the bottom but I used the top one just for that reason. Neater, more practical and outa sight.........
    [​IMG]
    Fiamma Awning Rain Guard
    CODE: FIAMRAINGUARD
    [​IMG]
    RRP: £7.89
    Price: £5.99 – £6.49
    You Save: £1.90
    [​IMG]Size
    [​IMG]
    Qty:
    A convenient rubber guard sealing the space between the awning and the vehicle wall to prevent water from coming in. Easy to install without removing the awning, available in three sizes and sold per meter.
    Features
    • Rubber strip
    • Sold by the meter
    • Available in three sizes:
      • Small
        • For awnings installed with standard AS 120 brackets on flat walls
        • Width: 1.6cm
      • Medium
        • For awnings mounted with an adapter spaced out from the wall (up to 4cm) or on curved walls
        • Width: 4cm
      • Large
        • For awnings mounted with an adapter spaced out from the wall (up to 9cm) or on curved walls
        • Width: 9cm
    • Useful Useful x 1
  11. Wombles
    Wombles Funster
    Oct 28, 2013
    2,208
    1,739
    Somerset
    As with most things Fiamma it is a great little piece of kit, easy to fit, neat & works well (y) No more rain pouring down behind the awning & over the door when we have an awning attached :) Should probably have been fitted with the awning by the dealer but wasn't in our case.
