any ideas why
Discussion in 'Fridges & Ovens' started by scammellmanswife, Oct 20, 2013.
  1. scammellmanswife
    scammellmanswife Funster
    Dec 4, 2012
    676
    630
    leicester
    Why is my domestic fridge producing a big pack of solid ice on the upper part of the back wall inside. :Eeek: None of the produce is freezing thank goodness
  2. movan
    movan Funster Life Member
    Dec 2, 2009
    13,977
    25,438
    Moving around
    Hi Hilary, Is the seal on the inside of the door coming loose at all? Has the door not been closed properly?
    Sorry, other than those two reasons which made mine do the same I cannot think of anything else. Joy
  3. lorger
    lorger Funster
    Jul 11, 2008
    6,344
    7,796
    Dumfries
    i was going to suggest the same as Movan as ours did this and it was the door seal, due to it not closing the fridge was working harder to keep the temp low
    • Like it Like it x 1
  4. scammellmanswife
    Dec 4, 2012
    676
    630
    leicester
    Thanks for suggestions. I have checked the seal and cant find anything wrong with it really. It is only two years old but is out of guarantee of course :Sad: The false wooden door that is bolted to the fridge door has come loose at the bottom and does sometimes need an extra shove to get it flush with the adjacent door so mabe that is the problem but I have never suspected that the actual fridge door was not properly shut if that makes sense :Eeek: I can hear the motor working hard and its slightly warm where the vents are at the base of the fridge which cant be right can it ?
  5. greygit
    greygit Read Only Funster
    Aug 11, 2009
    274
    232
    Forest of Dean, Glos, France and Spain
    We had this problem with a fridge in the house once and it turned out to be an insulation problem, luckily for us it was still under warranty.
  6. Tootles
    Tootles Funster
    Sep 14, 2013
    9,267
    33,254
    Lancaster
    We have a (newish) fridge, and like yours its integrated into the kitchen units. One thing we have found, is that if you place anything against the back wall of the fridge, (packets, wrapped food etc), the fridge goes ballistic, and within a short time, the produce is frozen into a block of ice that would make a woolly mammoth ashamed! Not only are items frozen, but they stick to the rear of the thing, making it almost impossible to remove them. I asked a kitchen engineer why, and he said that this type of fridge is designed to condensate on the back wall, putting stuff up against the wall stops the air circulation, and the condensation solidifies into ice, very much as it does in the freezer box.
    Hope this helps. Our fridge by the way is a Bosch.
    • Like it Like it x 2
  7. scammellmanswife
    Dec 4, 2012
    676
    630
    leicester
    Thanks for that I am going to defrost
    :Rofl1: it now and do as you say and see what happens. We do keep boxes of insulin in there and they do get shoved to the back along with all the other stuff of course so mabe that is the answer. Will keep you updated :Smile:
  8. trophychap
    trophychap Funster
    Dec 24, 2009
    731
    5,798
    bedworth warks
    OMG - you've more than likely killed that insulin then! :Eeek:
    Jen keeps hers in the top compartment of the door in our fridge - before they invented such things the vials just fitted nicely in the egg rack - one egg space per vial - this was before they invented pens or pen cartridges too! But we've gone full circle now - cos on a pump she's back to vials. :Smile:
  9. scammellmanswife
    Dec 4, 2012
    676
    630
    leicester
    Will keep you all updated on him too then :Eeek:
    Seriously tho I don't think they bin frozen as I said contents are not freezing up the boxes would act as insulation wouldn't they ?
  10. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Too much in a fridge will cause it to freeze up - air needs to circulate around the fridge, and particularly near the back coolings fins.
    Also, temps below 10 degrees (IIRC) You need to cover the outside vent to stop the fridge over-cooling, which again will cause freezing up.
  11. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    What you can try is to run your hair drier around the inside door seal a good few times it re activates the seal, our one at home was acting up that cured it. Pete
  12. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,640
    1,471
    West Midlands
    If the remedies do not do the trick it may be worth making enquiries about your waranty. Don't just assume that it's 12 months. Many electrical items are covered for longer so do check rather than assuming.
    Wyn.
