Antifreeze
Discussion in 'Motorhome Chat' started by Fermenter, Nov 4, 2012.
  1. Fermenter
    Fermenter Read Only Funster
    Sep 6, 2012
    104
    15
    Preston
    Hi all can anyone recommend a brand of antifreeze for the grey waste tank and fresh water tank please. :thumb:
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Hi you can stick any in the waste tank:Eeek: but would not put any in the fresh :thumb:better to drain the system down
    terry
  3. paulmold
    paulmold Read Only Funster
    Jun 15, 2009
    895
    301
    North Wales
  4. normanandsue
    normanandsue Funster
    Dec 31, 2010
    1,311
    4,274
    Dunfermline - Scotland
    My manual strongly reccomends not putting antifreeze in the grey tank as it is a corrosive and could attack the seal joints. Regards fresh water tank if the possibility of freezing is a worry when you are using it in winter then take bottled water with a refill often.
    Norman
    • Like Like x 1
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    the correct way to use safe, non toxic antifreeze is to drain the system fully first, including the boiler.
    then introduce the antifreeze and draw through all water lines until it comes out the hot and cold taps....including the shower and toilet if fed from the main tank.
    if the toilet has its own tank then dose that and draw through to the toilet bowl.
    then turn off the pump and leave the taps open.
    it isnt toxic but does have a slight taste so will need draining (you can reuse it next year) and flushing through before recommissioning the water system after winter.
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    Your fresh tank is inside, you don't need antifreeze!
    If you are standing the van up for winter, just drain it down!
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    even a water tank inside the van will eventually freeze no matter how much insulation it has unless the tank is heated. we don't drain down until a bottle of water stood in the sink freezes then I know that in a day or three the tank is at risk
  8. paulmold
    Jun 15, 2009
    895
    301
    North Wales
