Another panel advice thread . . . (1 Viewer)
Jun 23, 2013
251
131
Hurworth-on-Tees, Darlington, UK
Knaus Sun Ti 650 MEG
Since July 2013 but been camping for 25+ years
Jul 23, 2013
381
221
Scotland
knaus van ti 600mg
Getting There since 2013
The extra cost is for the "mppt charge controller" which is worth getting. What size is your battery bank and how much space you got on your roof.
chopper602
Jun 23, 2013
251
131
Space on the roof isn't an issue, I'm having trouble actually finding my leisure battery! It's under a panel in the floor somewhere. Keeps us going for about two to three days off grid (fridge on gas all lights LED).
Jul 23, 2013
381
221
Scotland
knaus van ti 600mg
I would find out what leisure batteries you have as its going to help determine what size of solar panel you should get (im sure 100w should be fine) and if roof space isn't an issue then it maybe fitting 2 ;) but that would depend on if you see yourself going to increase your power usage in the future!
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Have a look underneath van you will see a drop section thats where battery will be if youve checked everwhere else regards
chopper602
Jun 23, 2013
251
131
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you have the roof space an spending on an extra panel is better than spending on a mppt controller
chopper602
Jun 23, 2013
251
131
This one panel will do me for now. There is a satellite dome already fitted and three rooflights, so this one will about fill the roof. We don't do that much wild camping, so this will top us up nicely when we do.
Badknee
7,407
412,082
notloB
Vantage Neo
Living the dream.
A very good comment was made on here in that thousands and thousands of pounds are wastefully spent on solar panels and battery banks that people think they will need but actually don't.
We plan to use this summer to do what we want when we want and if we run out of electrickery doing it we will do,something about it.
People tell us that they wild camp and so need this and that, well so do we but not for more than a couple of days and we move on thus charging the batteries we have, each to their own, if your stopping put for weeks at a time then it's a different matter but try before you buy. :D
chopper602
Jun 23, 2013
251
131
Well I know for certain I will be in the same place without EHU for at least 4 days in two locations this summer. That's not including the two or three days stops we might take elsewhere.
I don't feel I need to justify my purchase. It's a complete kit from a reputable company, so at the very least I've got some guarantee.
chopper602
Jun 23, 2013
251
131
Had a good look, and found a panel on the floor under the table and behind the cab seats (need to remove a small piece of trim, but it's constructed to allow access) and there it was - Banner Running Bull AGM 12v 95Ah 850A. Going to try and get the panel fitted next week, been hectic here to get anything done sooner.
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Ask these people to put a kit together for you, at least you will get 4mm cables and the upgrade to 6mm will be minimal.
You are likely to find that tightening the entry glands on to 2.5mm cable is difficult, 6mm cable will give a better seal.
http://www.solarenergyalliance.com
They couldn't have been more help when I bought things from them.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
can anyone recommend a complete one panel kit plse..I have two matched leisure batteries. and an idea as to weight would be helpful :)
Are the Bosch panels any better, as seen on ebay
chopper602
Jun 23, 2013
251
131
Take a look at the link at the top of the thread - they do complete kits, it then depends how much power you want or how much you are prepared to spend!
funflair
19,305
30,072
Guisborough
MORELO palace
since 2012
Make sure you solar regulator is set to AGM when it fitted.
chopper602
Jun 23, 2013
251
131
Just paid for the installation today - very pleased with Teesside Caravans!
3 hours was the book time, no idea how long they actually took but it's very neat. I also mentioned that the hab door was dodgy and they've fixed that too (for another ½ hours labour!). Had a quick look at the display and it's kicking out over 14v at about 2amps. Battery voltage was nearly 13.5v or thereabouts.
Newby Hall, wild camping at the end of the month will tell me how effectively it's working !
chopper602
Jun 23, 2013
251
131
First use of the solar panel in anger and it worked very well and am very pleased with it. Not so pleased that in fitting they seem to have introduced a leak !! Noticed a bit of water on the shelf under where the wires enter the hab. So I dropped the keys back off with them and they're going to look at it. It must be getting under the gland as the wire rises up before entering there. There is a lot of sealant up there, so looks like they've just been a bit unlucky . . . .
After it's resealed, there is nothing more I need to do is there?
43,304
49,292
If it's 14v at the controller and 13.5v at the batteries you have some serious volt drop.
The battery voltage or remote voltmeter should show the same voltage as at the controller.
