Another Leveling Question (1 Viewer)
Biged
159
70
Nottingham
No longer looking
newbie
We are soon to be the proud owners of a Ford Transit Chassis based MH, it has twin wheels at the rear, are we going to need 3 leveling ramps :Sad:
Aug 4, 2013
1,140
139,975
Oop North
None now šŸ˜¢
Sorry I don't understand about only needing two can you explain a bit more please.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
We have a 6 wheel Transit.
Just put the ramp under the outer wheel if you you are using the other ramp at the front.
We get by just fine with a pair of Milenco Quattros.:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
The RWD Transit in 6 wheel form has dual rear wheels on a single drive axle, not a tandem rear axle.:thumb:
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
you will manage fine with two usually, as you only really need to use the outside wheel at the rear. More often than not you will be levelling either the front up, or the back up, or one side or the other. In worst circumstances where the ground is so bad you need to level three corners, just move to a better site.:thumb:
Aug 4, 2013
1,140
139,975
Oop North
None now šŸ˜¢
Thanks but its too technical for me i will ask my husband he will understand! :Eeek:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
a levelling ramp is only one wheel wide so to level front and rear under all wheels could use 3 ramps but in practice two are fine if you bother at all, we never do.
missbusybusy
93
36
Northampton
C class
newbie again
Hi you will only need one ramp for one of the rear tyres (wheels) unless you need the whole of the rear of the vehicle raising then use one ramp for each side of the van on the outer tyre (wheels) and one ramp for the front tyre if you are raising one side of the vehicle
carol::bigsmile:
Rapide561
471
167
Leeds and Lake Garda
Ramps
Don't bother with bought levelling ramps - make your own. I usually get my wood out of a skip or somewhere, so it is free. Sometimes I go to the timber yard and they find a bit off the floor. I put a few bob in the air ambulance box on the counter.
My last piece of wood was from outside a house in Boroughbridge. The house owner had a sign up selling eggs and so on, so I bought some, then I spotted the wood. I asked for a piece and he gave it me, but also cut it - see here for some ideas.
We are a tag axle rather than twin rear wheels, so we have two short pieces for the front if needed and one long piece for the rear. This allows us to lift the front using the two shorties, or lift one side using a long and short piece. I have never had to lift the back end as the van is slightly nose down at the front anyway.
Russell
