Douglas
Don't they teach hill starts these days? You know, handbrake/clutch/throttle!!!
Doug...
Doug...
He's serious folks, you should have seen him sling that 3 tonne motor home around on the grass at Banbury........
..........Good old Chris, 73 years of age and still 17 at heart....
Doug...
Another example of dumbing down a skill and worse, something else to go wrong.
I cringe and spit fire at the number of people I see holding cars on a hill at traffic lights. Incompetents.
:thumb:HOW OLD blimy Chris your wearing [STRIKE]well[/STRIKE] out :thumb:
look good for me age dont i:thumb:HOW OLD blimy Chris your wearing well:thumb:
...and as for that gearbox that works in reverse........
I was on the M6 earlier and was counting the millions of different variants the Transit comes in. I lost count after seeing at least 10 different current types of transit. Van, MH, Minibus, Recovery Truck, Flat Bed, etc..... Each of them in various types, LWD, SWB, Twin rear Axle, etc...
Hi Brian!
Are you going to remove the altimeter from that glider? Isn't that an example of dumbing down?
Then I saw Top Gear and that lady racing driver Sabine Schmitz racing the transit around Nurburgring. Following day..Ford Transit order placed!!!
that aint got sheep in?Ah, a joke that backfires !
One of the routine "keep you up to scratch" tests is just that, cover up airspeed and altimeter. They do fail so we learn to cope without them.
Altimeters are in "continuous fail" mode anyway. They are based on pressure ( which changes ), so on take off they are usually adjusted to read zero. But unless you are in Norfolk as soon as you move away from the field the altimeter is telling you nothing. Camphill is 1340 feet about mean sea level, fly half a mile south and it's 500'amsl but you don't know this exactly so your altimeter is telling you little about your current situation.
The real altimeter is between your ears, for example, at 2000' a sheep is a white dot, 1500' white sacks, 1000' see head/shape, 500' pretty sheep. So the plan is, see "white sacks" and find a field to land in.
So why not fly all the time without your dials?
Two dials.....
Altimeter, an example: above Camphill is a height limit of 10000' based on an the standard altimeter setting of 1013mb. Above that we might get eaten by a Jumbo and certainly by an Air Traffic Controller. With permission from Manchester control, the record over Camphill is something like 23,000'.
Air Speed, it is possible to fly without one by feel/sound but not to get the best out of a glider. Every glider has one speed for best performance, around 40/50 knots, to glide the maximum distance you need to be bang on this.
Two dials.....
But still, why not glide without them? Surely good skills could be used?
Aha! Just the point!
The HLA can make a better job of doing a hill start than I can by either holding or using the Handbrake.
Ain't technology great!
next it will be the auto park button so the vehicle parks its self.
But it's a faff in a MH to reach down and put the handbrake on if you are only stopping for about 10 seconds, before moving 5mm and then stopping for another 10 seconds.......
Advanced driving will tell you not to use the handbrake, but keep the car in gear with the footbrake on, or at least they used to.
