Another fridge thread, sorry!
Discussion in 'Motorhome Chat' started by DanielFord, Sep 21, 2015.
  1. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,512
    2,735
    Surrey
    OK this weekend I finally decided to fit the cooling fan to our fridge. It has been sitting in the pile of "things to fit" for a couple of months now. And since the van wasn't being used it seemed like a good idea.
    Anyway, onto the point. In order to fit the fan, the fridge has to be removed, so I disconnected it all, and slid it out. Now I had intended to take the fridge to the garage and work on it in there, however, I quickly discovered that the fridge is larger than the width of the habitation door! Not a problem, I simply went and got an old sheet and worked on the fridge in the van.
    Whilst I was working away, a thought occurred to me. How the bloody hell does one replace the fridge if it ever breaks completely?
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,676
    23,051
    Narrfoook
    On ours, it is a bit complex..
    Remove fridge and place near door.
    Refit fridge and buy a new motorhome with working fridge
    Seriously, ours will JUST slide through..
    If you have a fixed bed with a lift up base in to the garage I 'spose it might be possible to pass it through the bed, into the garage, and out that way..
    Short of that a jigsaw to remove the side of the van and duck tape to put it back afterwards !!!!! ????
    • Like it Like it x 2
  3. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,429
    12,432
    East Sussex
    If it wont go though the door you could always take the windscreen out :whistle:
  4. M1ke
    M1ke Funster
    Mar 12, 2012
    189
    104
    Huntingdon
    Funny, but that thought occurred to me the other day and the only thing I could think of was to remove the habitation door frame which may give you a bit more room or somehow man handle it out of the passenger door after removing the seat?
  5. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,088
    2,950
    Essex
    I have heard if you take all the surround off the habitation door might fit, else, through the windscreen!!
    • Like it Like it x 1
  6. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,512
    2,735
    Surrey
    That's a possibility!
  7. Jim
    Jim Ringleader
    Jul 19, 2007
    26,653
    78,867
    Sutton on Sea
    Ours was the same in the Hymer, you had to work on it in the kitchen, and with the tiny end kitchen that wasn't easy. They must build the van around the fridge. No accessible bottom vent on the outside of ours; so we took it out a few times just to do normal maintenance. That was before we discovered it was easier to drop the rear bumper. :doh:
  8. Jaws
    Sep 26, 2008
    18,676
    23,051
    Narrfoook
    Just thinking it through, if you removed the fridge door, would it go through sideways ?
  9. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,889
    1,773
    Cornwall
    Just a thought.
    Remove the passenger seat and exit fridge through front door(s)
  10. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    I found that by removing the fridge doors and hinges it would got through sideways as it is wider than it is deep.
    I have done this when I upgraded mine from a 7 to the 8 series
  11. Techno
    Jul 28, 2010
    14,187
    15,162
  12. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,889
    1,773
    Cornwall
    All I can hear in my head right now is that 1962??? (So Long ago?) rendition of "Right said Fred" by Bernard Cribbens.
  13. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,512
    2,735
    Surrey
    Do you know, I was singing that in my head whilst I was working :D
  14. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,512
    2,735
    Surrey
    I hadn't thought of that. Being a high-line, with the bed retracted, I could probably go over the passenger seat and out the cab door!
    Simple when you think about it! :D
