Another Cola related thread
Discussion in 'Top Tips & Tricks' started by vectian, Feb 27, 2015.
  1. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    I know about using cheap coke (not the powdered stuff cos that's expensive) to clean waste pipes and tanks.
    But is it ok to use in the Theftford cassette. I think that it must be scaled up in there because of the flaky stuff that comes out when I rinse it out after emptying it.
    Don't want to use the coke and rot the seals etc like its supposed to rot your guts.
    Thanks folks.
  2. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,875
    7,660
    Paignton, Devon.
    Baby bottle sterilising tablets? I've used them in the past, didn't seem to do any harm.m
  3. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,638
    3,195
    Cumbria
    I think it's the phosphoric acid in coke that does the business, someone on here suggested using citric acid from a home brew shop. It should be plastic safe too and no sugary residue to stick up your rubber seal and flap mechanism if you dont get it all rinsed off.
  4. scotjimland
    Jul 25, 2007
    28,934
    25,590
    Anything that is acidic will help remove lime scale.. ie with a pH below 7
    acetic acid.. ie white vinegar pH 2
    grapefruit juice pH2.5
    lemon juice pH2
    citric acid pH2
    Coca-Cola contains small amounts of citric acid and phosphoric acid.
    Phosphoric acid is commonly used for rust removal.!
    I'd use white vinegar ..it won't harm rubber or plastic.. about a cupful and fill with warm water.. not hot.. leave overnight and rinse..
    • Like Like x 3
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,720
    17,333
    YO11 2BD
    The small amount of acids in cola probably wont have any affect on scale.
    its ideal for removing sludge type deposits.
    As scotjim said.....cheapest white vinegar, then a bit of pongy stuff to mask the vinegar smell.
  6. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,685
    1,296
    living the dream.
    I often use citric acid to clean stains from the toilet bowl which in turn goes into the cassette.I sprinkle some around the edge of the inside of the pan, leave for around half an hour, all stains are gone.
    When at a borne I sprinkle some citric acid around the seals, with rubber gloves on I work that into the crystals that have built up from our wee, you can feel it removing the crystals from around the seal.
    Not a nice explanation but has to be done otherwise blades on the cassette get difficult to open and might possibly break during operation.
  7. WillH
    WillH Funster
    Feb 9, 2008
    1,689
    1,380
    SW Scotland
    I just use vinegar.
    • Like Like x 1
  8. enuf
    enuf
    May 10, 2009
    11
    Liverpool
    I use lemon juice to clear limescale in my kettle, but coffee tastes awful when you forget to rinse the lemon juice out properly!
  9. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,044
    2,919
    Essex
    Glad I don't drink a lot of coke
    :wine::rofl::rofl:
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,586
    5,648
    West Sussex
    I use white wine vinegar, it work well also Truma recommend it for descaling the hot water tank. I stock up in France 33 cents/Lt.
  11. rich g
    rich g Funster
    May 29, 2014
    241
    348
    Worcester
    In the Thetford cassette when i empty it before leaving the site i put in some water and a laundry tablet(from lidl) in the cassette so it swills about on the way home then rinse it out when home.
    I also use the tablets in the cassette when ever i empty it.
    • Like Like x 1
  12. rangitira
    rangitira Funster
    Jun 30, 2010
    6,328
    12,867
    Cornwall
    Someone, can't remember who, said Pork cooked in Cola is very tasty, anyone tried it?
  13. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,946
    9,053
    Wrenthorpe, Wakefield.
    Me.
    And it's a It's a ham joint. I do it every Boxing Day .
    Boiled in propper coca cola . Then taken out put in the oven. Skin pealed off then scored , Drizzled with honey and coarse grain mustard. Finished off in the oven to brown it.
    It's yummy.
    • Like Like x 2
  14. rangitira
    rangitira Funster
    Jun 30, 2010
    6,328
    12,867
    Cornwall
    OOOHHH! Any room in your spare bedroom this Xmas?
    • Like Like x 1
  15. Dazzlin
    Dazzlin Funster Life Member
    Oct 31, 2012
    835
    1,643
    on the road
    Nigella!
