Another Bike Rack Question .... Sorry (1 Viewer)
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Evening all,
I'm after a bike rack for the van, it's a PVC with twin doors at the rear.
Having reservations about the Fiamma carriers and possible door damage so we have decided to go down the tow ball mounted route.
Anyone on here use a Saffier cycle carrier and if so how is it attached to the tow ball?
2dogs
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Give us a call for more info 01-580-883062, there is also a 3 bike version, max load 60kg
http://www.johnscross.co.uk/saffier-towball-bike-racks.html
Saffier 2 Bike Carrier Towball Mounted
This is the next generation 2 bike carrier from Tradekar, it is a superb tilting four bike wheel support rack that fits all tow balls and all bikes.
Saffier 2 Bike Carrier Key features:
  • It's very quick to fit and dismount
  • The carrier is easily tilted even with the bikes on
  • The bike frame holder folds flat for ease of storage - you just need to undo two hand tensioned wheel nuts
  • It comes supplied with both the 13 pin continental socket and the UK 7 pin so no adapter is needed (The fog light will only work when the 13 pin system is used)
  • The wheel supports are fully adjustable so the carrier can take any size of bike
  • The strong quick fit / quick release polypropylene straps accommodate all wheel sizes and all frame sizes
  • We recommend that you buy a cable lock if the bikes are going to be left unattended. Pass it through all the bikes and around the carrier
  • Bike carrier weight = 14kg, max load = 60kg (please also check your tow ball nosewieght)
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks John,
will be the 2 bike we're after, will call sometime next week
2dogs
Stonemags76
1,280
3,994
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Can anyone tell me if it's possible to open the van doors when the tow ball bike rack is tilted please? We don't want to have to take the bikes off as the first job every time we stop!
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Jim,Pat,
I've looked at both Thule, Atera and Witter racks, all look good quality. Just never heard of Saffier racks and wondered about the quality.
Stonemags, I've got a feeling that even with tilting racks, if the bikes are on you won't be able to open the doors fully.
2dogs
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
If you need access to the back doors then the Fiamma one would be best. If you are carrying no more than the rated load of 45kg you should be okay but just in case I have bolted the top rail of mine on .
Mike
Minxy
32,649
66,537
E Yorks
Carthago Compactline
No you won't be able to, you can only do that when they are installed on a car tow-ball with a lift up boot/tailgate.
Minxy
32,649
66,537
E Yorks
Mike
Just to correct you ... the rated load is 35kg not 45kg ... it took me a long time to find a couple of electric bikes that were light enough (without batteries) to be able to go on the rack that came in under that weight.
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
Thakyou. No wonder my steering feels light.
Mike
Minxy
32,649
66,537
E Yorks
One 'cheap' on Ebay, there are others too (Fiamma 200 DJ):
Broken Link Removed
Minxy
32,649
66,537
E Yorks
g8ysn
638
417
ng219ep
coachbuilt
2 bike carrier from Halford fit on tow ball with locking device about 50 pounds on off in 30 second will upload photos later
g8ysn
638
417
ng219ep
coachbuilt
I find this an ideal set up fit,s on car and camper,bikes could,nt decide on road or off road so bought a pair
suit.s me
