another battery problem
Discussion in 'Motorhome Chat' started by poppys, Dec 18, 2010.
  1. poppys
    poppys Read Only Funster
    May 8, 2010
    166
    41
    Norfolk
    I have to use my motorhome as transport for work,a journey of less than 2 miles, it alo has to be moved from my drive regularly to allow my wife to put her car in the garage.The batt lasts 2 weeks without strugling to start and then it is Ok again if I drve it for a 50 mile journey.
    Questions :
    Is my batt acting in a normal manner ?
    If I disconnect it to charge it,will I only have to reprogram the radio ?
    Base vehical is 2 LTR Peugeot HDI
    Thanks in advance Chris
  2. scotjimland
    Jul 25, 2007
    28,934
    25,589
    1. Yes
    2. Yes, you will need the code for the radio and you will lose the pre sets..
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    If it is parked on your drive is it not possible to run a hook up to it.
    It would be easier to unplug when required than remove the battery to charge it. That way you could charge as required.
    Dave.:thumb::thumb:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    curious as to why you need to remove the battery to charge it ?
    with a small battery charger, something like the C-tek range, could be placed under the bonnet, out of the weather, along with the mains extension lead socket once every week or so to recharge.
    [​IMG]
  5. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Glad you raised this John..
    I have a similar problem to the OP .. (doing too many short runs and not charging the battery properly )
    I was going to invest in one of these chargers from Aldi .. but then read the Honda user manual which said NEVER to charge the battery in situ without disconnecting the earth lead as it could damage the ECU .. so on that advice I remove it to the shed once a week and put on a normal charger overnight.
    Is this being over cautious or a real danger ?
  6. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    well Jim, if honda recommend removal then so be it......ECU's aint cheap but i think they are being a little over cautious.
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    you could always get one of those battery isolation switches and connect it to the negative side instead of the positive then you just turn off the red key and charge the battery.
    andy :thumb:
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Jim I have the van on the auto x5 from Aldi on 24 / 7 without harm :thumb: I also put the pick up on ( L200 ) on every couple of weeks without harm :thumb: Never disconnect either.The L200 only gets short runs 1 mile each way or say 4 mls each way so takes a lot more out of battery than gets put in.Use an auto x 5 on both or some times change to the Tronic from Lidl :Rofl1:
    terry
  9. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Thanks Terry
    I'm pretty confident it would be ok ..but think I'll err on the side of caution .. if I damaged the ECU the warranty wouldn't cover it .. best play safe.
    I fitted a new Varta battery last week and keep the old one on charge so I can use if need be to jump start.
  10. motor roamin
    motor roamin Funster
    May 23, 2010
    1,535
    785
    Leicester
    I can't remember the reason Jim but certain cars are best not having batteries charged on the vehicle both my mercs are like this also, I seem to remember it has something to do with spikes while charging.
    I am definatly not an auto sparks, in fact I have always hated auto electrics so if I am told not to do it I dont as I have had nightmares with my S class £2,000 plus in two years on an incurable problem that only shows up at this time of the year.
    I know this aint too helpful just thought better safe than expensive.
    All the best Rick.
  11. poppys
    May 8, 2010
    166
    41
    Norfolk
    Thanks for the replies,my Peugeut handbook states," Never charge a batt without first disconnecting the terminals",and the Explorer handbook under the control panel does`nt mention charging the vehical batt via the panel at all. This is why I was going to disconnect the Batt and charge it in situ,but Im concerned that once reconnected the electroniic system would not reset itself fully, as the Peogeut handbook states " If slight difficulties are experienced after reconnection please contact a Peugeot dealer".So i would be stuck with the motorhome unable to be used and blocking the drive so my wifes car would be stuck in the garage.
    Ps I don`t have a lot of confidence in my local Peogeut dealer on their past record.:RollEyes:
