Another 12v fault, seem to be a few on here at the moment.
Discussion in 'Tech/Mech General' started by Encantador, Apr 4, 2015.
  1. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Arrived at Chester Thursday, plugged TV in bedroom into cig socket, no power. Pressed all fuses, power came on, great, sorted. Watched TV then unplugged TV, next day when plugged back in, no power again.
    Checked fuses, the only mention of TV on fuse board is a 10amp which says TV socket / hob ignition. Hob ignition is working fine, so unlikely to be fuse. Checked all fuses, all look ok.
    Had dealer fit outside power / aerial socket when we purchased the MH, never used it, it is just below bedroom window dropped TV lead through window and no power to that one either. Because of the location I assume they took the power and aerial feed from the ones in the bedroom.
    I have removed the face plate from the bedroom socket and cables seem tight. I can just see a black pencil with object with a silver end, just wondering if this might be a fuse holder of some kind. Should there be a fuse there?
    I can't get at it without removing the front plate which risks losing the cables when detached from plate, so don't want to go there if there is nothing inside that might be the problem.
    The only other 12v socket is in a cupboard on the other side where the TV aerial is situated and that is working fine.
    Any help/ advice would be appreciated.
    Steve
  2. f6c
    f6c Funster
    Nov 7, 2010
    3,374
    895
    gloucestershire
    Sorry Steve cannot help you.
    • Like it Like it x 1
  3. PeteH
    PeteH Funster
    Nov 22, 2007
    2,213
    2,753
    East Yorkshire
    Just a Thought. Did you TEST the fuses or just a visual check?. I chased a 12v fault for ages before I went back and Tested a fuse only to find it was "blown" It looked OK.
    Pete
  4. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Thanks for the replies.
    I changed the fuse that mentions 'TV socket' the rest I visually checked.
    I would have assumed that both TV sockets, the faulty one and the working one in the TV aerial cupboard (excluding the one fitted outside) would be on the same fuse.
    I am hoping what I can see behind the panel is another sort of fuse, if not, presumably it could be a wiring problem, which could be anywhere.
    Steve
  5. Polar bear
    Polar bear Funster
    Nov 13, 2012
    207
    134
    Somerset
    Is the fuse the correct value for the equipment you are using
  6. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Thanks for the reply.
    No idea, but have not had a problem with it in the last 2 years, using the same equipment.
    Steve
