Amps / watts - French site help.
Discussion in 'Tech/Mech General' started by Jph123, Nov 11, 2013.
  1. Jph123
    Jph123 Read Only Funster
    Nov 2, 2013
    59
    64
    Devon
    Hello!
    Just planning ahead as hitting the French alps in 3 weeks.
    We'll I'll keep it short, I just don't trust leaving my propane heater on overnight, as a couple of times it has cut out and both times, both engineers have said its fine after many hours of fault finding nothing.
    Anyway, daytime when I'm awake fine, but for nighttime I have two 600w mini oil filled radiators, which don't trip uk sites but I'm told French sites trip a lot easier to trip as lower amps? Will my two radiators plus usual lights etc do this?
    Any advice welcome.
    Thank you
    Justin
  2. Mikeco
    Mikeco Funster
    Sep 26, 2013
    724
    534
    Market Rasen
    It all depends on what the campsite is supplying. You need around a 6 amp supply and some sites do offer less than this. In my experience though most will provide enough for your needs.
    Mike
  3. estcres
    estcres Read Only Funster
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
    It depends on what amperage supply you have:
    If it's 6Amp you are right on the edge of capacity with your 2 x 600watt heaters, together they will use about 5.21Amps (1200w / 230v = 5.21Amps)
    Add on to that your kettle etc and you could well be over the 6Amp supply.
    If you have a supply higher than 6Amps you should be OK.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    and more importantly, the parasitic load you forget about......the battery charger.
    that aside, your gas heater should be sealed to outside air....in other words whether its running or not no fumes of any description can enter the hab area from the heater and if it should go out the thermocouple will shut off the gas automatically..
    • Like Like x 1
  5. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    522
    near Boston Lincolnshire
    as a rough guide just use 4 amps per kilowatt (1000w) to work out your consumption:thumb:
  6. Jph123
    Nov 2, 2013
    59
    64
    Devon
    Thank you - very helpful
    Thanks everyone very helpful advice, should be ok with the ski site as they have a 10 amp option which I will take for sure.
    You are all a very wise bunch.
    Thank you
    Justin
