Amp Hours - please educate me
Discussion in 'Tech/Mech General' started by laser101uk, Mar 14, 2014.
  1. laser101uk
    laser101uk Funster
    Jun 6, 2012
    338
    851
    Basingstoke
    so, I am a little confused by the term amp hours. I understand that my battery is say 100 amp hours, I assume this to mean that if i was running a 1 amp appliance I would then be able to run it for 100 hours ( I realise not to run the battery below half way) so with this in mind my 1 amp appliance would run for 50 hours.
    Therefore If my TV is rated at say 4 amps, according to my thinking I use 4 amps per hour from my battery full of amps....
    I am sure I have got this wrong, if anyone can please enlighten me I would be grateful...
    Steve
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,154
    1,883
    London
    I am no expert but that is about right. So your tv would run! workaround twelve hours
  3. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    Spot on Steve :thumb:
  4. Microchip
    Microchip Funster
    Apr 8, 2012
    135
    125
    Hampshire
    This the best way it can be explained
    The Amp Hour rating tells you how much amperage is available when discharged evenly over a 20 hour period. The amp hour rating is cumulative, so in order to know how many constant amps the battery will output for 20 hours, you have to divide the amp hour rating by 20. Example: If a battery has an amp hour rating of 75, dividing by 20 = 3.75. Such a battery can carry a 3.75 amp load for 20 hours before dropping to 10.5 volts. (10.5 volts is the fully discharged level, at which point the battery needs to be recharged.) A battery with an amp hour rating of 55 will carry a 2.75 amp load for 20 hours before dropping to 10.5 volts.
    Keith
  5. Yorick
    Yorick Funster
    Oct 1, 2013
    4,061
    5,986
    Lanzarote
    BBC is posher than the rest, so uses more leccy :Smile:
    • Like it Like it x 1
