Amitage A -frames (1 Viewer)
Oct 26, 2014
1,869
3,198
Dumfries and Galloway
Pilote P696GJ
I had an A -frame conversion recently fitted to SWMBO's Skoda Fabia TDI by Armitages at Ferrybridge and while I'm happy enough with the set-up I didn't realize how heavy the A frame was going to be .
In fact its just heavy for me lift as I have back issues , Armitage's say its 30kg as its the heavy duty model which is needed since the car weighs 1170kg but I would say its nearer 40kg .
Does anybody know of any other A-frame manufacturers that make lighter models that perhaps would marry up to the existing towing eye attachments .
Neil S
Oct 26, 2014
1,869
3,198
Pilote P696GJ
In fact its just to heavy for me to lift as I have back issues , Armitage's say its 30kg as its the heavy duty model which is needed since the car weighs 1170kg but I would say its nearer 40kg .
43,323
49,427
All the A frame manufacturers use their own prefered method of attachment to the car so its very doubtful any other make will fit.
Neil S
Oct 26, 2014
1,869
3,198
Pilote P696GJ
Thanks for the your reply's , theres a company called Chesterfield Towing A frame's who advertise on Ebay claiming to have stainless a frame so may give them a call
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
yes the place in chesterfield are claiming that their A-frames weigh 12KG,but as John said I doubt very much if they will be compatable with your existing system.
Brian & Jo
Minxy
32,646
66,526
E Yorks
Carthago Compactline
What exactly is the problem with lifting it - is it just so that you can put it on/off the tow ball - if so then I'm sure there'd be a way of sorting something to make this easier.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Lightweight A frames are used where the braking device is electronic and fits in the drivers' footwell. They're lightweight because they don't have the braking mechanism, cable connection, etc.
Neil S
Oct 26, 2014
1,869
3,198
Pilote P696GJ
The problem is that its heavy , well heavy in my book and as I suffer from back problems due to an accident in my past working life I really struggle to lift it out of the car boot without being in pain .
It has a jockey wheel which really only helps with hitching up to the motorhome as I can drive the car with the A -frame attached and guide it onto the towball .
When the frame is assembled and attached to the car its easy enough couple or uncouple but its the lifting out of the car is the issue .
TBH if i cant get a suitably lighter A -frame attachment that I can manage then I'll have to look at other options perhaps a trailer or maybe just do without .
