AM/FM Radio Aerial for MH
Discussion in 'Motorhome Chat' started by veevee, May 12, 2012.
  1. veevee
    veevee Funster
    Jul 4, 2010
    1,016
    564
    Essex / central France
    Hello
    What's the current thinking on a good AM/FM radio aerial as fitted to a MH, there appear to be many options including expensive electronic interior ones.
    Usual plastic roof and alloy skin on side panels, both appear to create their own problems.
    For the cab radio there is an electronic one that is attached to the screen. It's ok but not good.
    In the dinette area we have another radio powered by the leisure battery, this has an aerial that is about to be removed for other reasons and can't use the same area to fit another.
    Any help much appreciated
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    Without fail the good old rubber duck on a front wing works every time:thumb:
  3. veevee
    veevee Funster
    Jul 4, 2010
    1,016
    564
    Thanks Geo
    It's an A Class with a plastic front panel and no wings, but I guess I could run a seperate earth to the aerial base?
  4. veevee
    veevee Funster
    Jul 4, 2010
    1,016
    564
    Geo, I am not very knowledgeable about radio frequencies and suitable aerials, and have just seen the rubber duck is a CB aerial.
    Is it suitable for good AM and FM reception too?
  5. scek
    scek Read Only Funster
    Jan 12, 2011
    134
    81
    Manchester
    Ditch the AM/FM radio and buy a DAB with a windscreen aerial. Best thing we ever did.
    Crystal clear sound and loads of stations.
  6. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,017
    5,371
    Wirral
  7. veevee
    veevee Funster
    Jul 4, 2010
    1,016
    564
    Thanks scek, but we spend a lot of time abroad and don't use our MH in the UK hardly at all.
    We are looking for local (to where ever we are) FM stations and UK AM stations when close to the UK.
  8. scek
    Jan 12, 2011
    134
    81
    Manchester
    I think I heard that France operates on different dab channels to the UK.
    I'll let you know in a couple of weeks what the DAB reception and number of stations are in France...
    The dab radio still has fm/am, but the fm connected to the crappy fiat wing mirror aerial.
  9. Geo
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    Hi Ve
    Your dead right rubber Duck is a CB slang term for an arial
    however it has been generalised to mean also the short rubber af/fm car airials
    Almost vandel proof cant be snapped off very easily, cheap as chips and not worth stealing, available at any car shop Halfrauds etc(not a spelling error):BigGrin: works extreamly well with standard radios,
    Yes make up an earth strap or small metal plate bolted to chassis and resting just inside the plastic panel of choice and mount arial through both
    As with all radios
    I normally say
    A quality radio deserves a quality arial
    A cheap radio needs one
    But for the money the rubber duck does it all:thumb:
    Geo
  10. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,017
    5,371
    Wirral
    If abroad you can increase the are where you can still receive by wrapping a couple of turns of insulated wire around the aerieal (no need to strip the insulation) and either stretch a long length of the wire to a tree or across the roof of the van. I have found that this gives that extra bit of range.
    Certain European cities,especially those towards the East have FM sites for the World Service.
  11. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Also suffer from the crappy fiat wing mirroe aerial and a crappy Autotrail so called media centre.
    What model did you go for .did you fit it ...........what is the windscreen aerial like.....? How much etc........
    thanks
    barry
    • Like it Like it x 1
  12. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Is this some sort of a wind up !!!!!
    barry:Smile:
