Alugas removable collar to reduce height? (RFG Q1)
Discussion in 'Motorhome Accessories' started by Soozywoozy, Apr 26, 2014.
  1. Soozywoozy
    Soozywoozy Funster
    Feb 18, 2014
    464
    416
    Oxfordshire - edge of the cotswolds
    it says is the collar removable to reduce height? On the calor gas they are welded and I have seen threads that show depending on age of cylinder they don't always fit. The alugas cylinders are 600mm - our locker is 640 internally but the door is 600. Presumably can tilt to get it in or does this contravene certain regulations?
  2. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,494
    894
    South Glos
    Yes the collars are bolted on. Indeed they have been removed on mine so that they fit in the locker
    John
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    Removed on ours as well. They are in the garage at home should we ever want to put them back.
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,606
    12,025
    E Yorks
    Have you considered the Gasit refillables, not as light as the Alugas at 10.7kg empty but shorter so unless you are short of payload these are a shorter (and cheaper) option:
    Height: 550mm height x 304mm diameter.
    ... at least you won't need to attack yours with a lump hammer like I did with my Gaslow bottle! :BigGrin:
