Alternator fuse Hymer (1 Viewer)
Patrick
366
11
Liverpool
2 year....Love it!
Due to the Hymer being a German import i dont know which fuse is which, Does anyone know which fuse will disconnect the alternator charging the habitation batteries Please!
Patrick
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Having studied my instruction leaflet and wiring diagram for the EBL99 (which is in German), I cannot identify the relevant fuse. Since the whole unit contains several charge relays, fuses etc. I suggest you e-mail Schaudt and talk to Sterling. They must have had experience of this.
scotjimland
2,323
10,021
A Woosh bang
Hi Patrick
Not having a Hymer can't be specific, the first place I'd look is beside the alternator, there is usually an in-line fuse in the cable feeding the habitation batteries..
Jim
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
what are you trying to do patrick?
Hi Ice,
I have done away with the batteries under the front seats, they were on their last legs, so have fitted 2 X 220 amph in the garage and fitted a Sterling battery to battery charger, the problem with the hymer is it uses and elctroblock which has a built in charger. the big issue is, my manual is all in German and the wire that charges the old leisure’s is the same wire that feeds all the 12 volt system in the van, I have to connect this wire to the new batteries and in doing so it will charge the new leisure’s at the same time as the new Sterling system, i would think combined it would boil the batteries. If i can identify the main charger fuse i can disconnect the old charging system and still use the wire for the habitation 12 volt system.
Hope someone can help!!!!!!!!!!!
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Hi Patrick, did you try e-mailing Schaudt like I suggested? The'yre pretty good usually and will normally e-mail you an english language manual in PDF format.
D.
JeanLuc
3,304
2,199
Warwickshire
Hi Ice,
Whilst you are e-mailing Schaudt Patrick, you might like to check whether the standard EBL is up to the task of charging 440Ah of batteries. If you have the EBL99 (which I have) it contains an integrated charger module LAS 1218 built into it. This is also available as a stand-alone unit and the recommended battery size for this is 55 - 180Ah according to Schaudt's UK leaflet. There is a facility to add a second LAS 1218 to your existing EBL in order to increase the charge-rate on hook-up. I believe it links into connector block 7 on the front of the EBL, but obviously you would need to get professional advice on this.
Philip
P
petes
schaudt
Patrick if you would like to drop me an email at
pete.schofield@live .co.uk
I will send you the EBL99 manual in english.
Also if you sort out the problem at the EBL end I would be interested. I have the same problem.
Pete
43,329
49,441
may be of no use whatsoever but my kontiki has two relay's connected to the engine battery(next to the battery) which is triggered by the alternator starting to charge.
one controls the charge
the other does the same for the fridge.
engine off...relay open.....leisure batt not charging
run engine...relay closed.....leisure batt charging
just a thought.
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
D.
Hi dave, yes i sent them an email, they replied asking the modle of the EBL, i didn't have it at the time just sent anohter with the numbers, it's EBL-104-3.
Fingers crossed they get back soon.
I have been told that i can use the two systems at the same time. My wory was that the Sterling charger is 50Amp and would it boil my batteries having the ordanary charger is still charging at the same time!
Patrick
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Hi Patrick, the two chargers might work together but the advice from Sterling is to disconnect the original alternator charging circuit to the leisure batteries. I doubt they'd "boil" the leisure batteries as this is more to do with voltage than current but you never know. General thinking is that the two systems can "confuse" each other if used in tandem.
D.
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
just a thought.
Hi Papa,
Thats just what the spak is going to do!
Has said he wants to put a 50 AMP relay in line with the main wire that used to go to the old leisure's this will switch of the charging to the batteries while the engine is running but still allow the alternator to run the electrics while the engine is running, this will let the step, fridge and other systems. when i turn of the engine it will make the connection to the batteries and all will run as normal.
The reason for such big batteries is i like wild camping, the sterling will give 99% full batteries and condition them. the ordanary chargers will only charge a battery to 80% and it will sufficate as the ordanary charger cant put in the firs stage high amp like the seterling will.
Patrick
Patrick
Patrick
366
11
Liverpool
2 year....Love it!
D.
Hi Dave
Patrick
